AI-Powered Asset Management for 3ds Max
Project Manager turns a sprawling 3ds Max library into something you can actually navigate.
At its core, a local AI engine organises your assets for you — classifying models, and letting you find them by plain description, visual similarity or colour, all on your own machine, with no subscription.
Around it sit the tools you reach for every day: merging, asset tracking, batch processing and deep customisation — built to keep even large teams and complex projects in order.
AI Asset Organisation & Search
At the core of version 4 is a local AI engine that classifies your 3D models automatically — by type, style, material and brand. Your library effectively organises itself, with no manual tagging, and everything runs on your own machine: no cloud, no subscription, your assets never leaving your computer.
The AI proposes, you decide — review, reassign or remove any suggestion at any time.
AI Text Search lets you describe what you need the way you’d say it out loud — “cube glass coffee table” — and see matching models straight away.
No exact file names, no categories to remember, nothing to tag first.
Type in your own language: over 30 languages are supported, so you search the way you think rather than the way your library was named.
Find Similar matches assets by how they look, not by their tags — filter a folder down to everything resembling a model you pick, search your whole library from one or several reference objects, or drag in a photo, render or even a rough pencil sketch and let Project Manager find the models that match.
Save references as reusable Reference Sets and switch between them in a click.
Colour Search finds both models and textures by colour — pick shades straight from the palette and watch the library narrow down in real time, with perceptual matching that understands how colours actually look.
Around this, Project Manager keeps your whole library in order. It has two main tabs: Explorer, for managing models, materials and other assets, and Asset Files, for the links used in your current scene.
The Explorer tab is split into four — 3D Models, Materials, Textures and IES Photometric files — giving instant access to external files straight from 3ds Max. Gather scattered folders into virtual Catalogs, which structure long lists of external folders without moving or duplicating the originals on your drive.
Each tab also carries a Categories section — a quick way to reach frequently used files and filter or search by name, description or category. Descriptions can be added to 3ds Max files, IES lights, materials and images, so even large, heavy scenes stay easy to navigate.
With the optional shared database mode, the folder tree stays synchronised across the whole team.
Adding assets to a scene
3D Models
Project Manager lets you merge 3D models directly into the viewport — as standard geometry, proxies, xRef scenes and objects, or Sini proxies. Most proxy types are supported: V-Ray, Corona, FStorm, Octane, Maxwell, Arnold, Redshift, Final Render, Sini and others.
Objects can be placed in the usual way, snapped to the grid, or painted directly onto the surfaces of existing scene geometry.
A wide range of formats is covered, including 3ds Max files, GrowFX, BIP motion, Archvision RPC, DWG, SketchUp and Revit. Select the asset you want and add it to your scene.
Materials, Textures and IES photometric lights work the same way — drag and drop them onto an object, into the Material Editor, or straight into the viewport.
Materials & Textures
Use Project Manager to organise your existing material libraries or build new ones from scratch.
You can also create materials on the fly: drag one or several bitmaps onto a model in the viewport, or into the Standard or Slate Material Editor.
PBR materials are generated in a single step, and more complex setups can be built by dragging bitmaps or Substance textures from Project Manager into your scene. VRscan materials are supported as well.
IES Photometric
Project Manager also creates IES photometric lights for realistic lighting, matched to your active render engine.
Each new light takes its parameters from the source IES file: light multiplier (in lumens), the shape of the light and its size.
IES files are rendered interactively, which makes picking the right one considerably faster.
Drag the IES file you want straight into the viewport — or use the replace function to create a photometric light exactly where your lamp geometry already sits.
Beyond that, Project Manager can replace, export and render previews for 3D models and materials.
Embedded previews are supported for 3ds Max files, GrowFX, BIP motion, Archvision RPC, DWG, SketchUp, Revit and many more.
Interactive rendering of previews works for Materials, IES files, BVH Motion, FBX, USD, OBJ, 3DS and a wide range of other formats.
Preview animated Archvision RPC
Interactive rendering 3D files
Create PBR materials
Asset Tracking System
Project Manager puts you fully in control of the external links in your scenes.
Asset tracking covers xRef files and makes working with external references straightforward.
From the Asset Files tab — and from Batch Render & Relink — you can find missing assets and relink external files across whole projects.
Editing and managing scene assets becomes far quicker: filter by name, asset type, file status or by the objects you have selected to locate exactly what you need.
The tool can also display, interactively, every asset linked to the objects currently selected in your scene.
Editing scene bitmaps is simpler too — any texture can be located and placed into the Material Editor in a single click.
Asset renaming and image resizing are supported as well.
Finally, entire scenes can be archived for backup or sent on to render farm services such as RebusFarm.
Batch Processing 3D Files
Project Manager also includes a set of tools for batch processing your assets.
These are Convert & Resize Images, Advanced Asset Renamer, Auto Assign Preview and Batch Render & Relink.
Batch Render & Relink is built to search for, relink and collect missing files across multiple 3D models and material libraries in batch mode.
As the name suggests, it also renders previews for asset files — 3D models, material libraries and IES files are all supported, across most 3D formats including max, 3ds, fbx, vrmesh, abc, cgeo and many others.
Custom studios and render presets are available for better preview results.
Convert&Resize Images
Batch Render&Relink
Customisation
Project Manager speaks your language. The interface is localised into 12 languages — and not just the menus: filters, tooltips and even the category names generated by the AI are translated too.
You can adjust almost everything else as well: how assets are merged and stored in the library, the studio used for rendering previews, and much more.
The interface itself is customisable — add icons to the toolbar or assign hotkeys to the menu items you use most.
On top of that, Project Manager has a MAXScript API that lets you extend its features and write your own tools for the tasks specific to your studio.
https://www.youtube.com/embed/6wKRcQLymdg
Why Choose Project Manager?
With version 4, a local AI engine organises your library for you: it classifies your models, and lets you find them by plain description, visual similarity or colour in seconds — all on your own machine, with no cloud and no subscription. Search in your own language, in an interface localised into 12 languages.
Drag-and-drop turns asset wrangling into scene-building: create complex materials and textures by dropping files straight onto your models or into the Material Editor, and merge objects as proxies or xRefs right in the viewport to keep heavy projects light.
The built-in asset tracking system fixes missing files across scenes and xRefs — collect and replace, search and relink, categorise and archive — helping keep projects intact when they move between workstations, folders or render farms.
In terms of compatibility, fully supported rendering engines include V-Ray, Corona, FStorm, Octane, Maxwell, Arnold, and many more, across 3ds Max 2016–2027.
Its interface is intuitive, so you can start right away. Studios and freelancers worldwide rely on Project Manager for everything from architecture and interiors to game levels and film scenes.
Whether you manage a personal asset collection or a shared studio library, Project Manager keeps the assets you need searchable, organised and ready to use — without taking you out of 3ds Max.
Main Features
- AI-Powered Search & Classification
- Classify 3D models automatically by type, style, material and brand.
- Describe what you need in plain words — no exact file names or categories required.
- Search in your own language — over 30 languages supported.
- Find assets by visual similarity from a model or reference image, or search by colour and name.
- Everything runs on your own machine — no cloud, no subscription.
- Interface Localisation
Work entirely in your own language: menus, filters and AI-generated categories are translated across 12 interface languages. - Easy Asset Import
Instantly add Models, Materials, Textures and IES files to your scene. - Archive Support
Browse ZIP/RAR/7Z archives like folders and drag assets straight into your scene. - Rich Thumbnails & Live Previews
Preview bitmaps (including HDR/EXR/PSD), 3D models, Proxies, Materials and IES files with real-time render. - Network Database Sync
Synchronise your asset structure (folder trees, categories and metadata) across users or workstations. - Silent Installation
Deploy Project Manager across studio workstations from a script — no need to visit each machine. - Unified Import Interface
Import via drag-&-drop, file dialogs, UI buttons, or API calls for maximum flexibility. - Versatile Model & Proxy Import
Merge geometry as standard meshes, V-Ray, Corona, Arnold, Redshift, FStorm proxies, xRef objects/scenes, SiniProxy, and more. - Slate Material Editor & PBR Creation
Drag materials into 3ds Max’s Material Editor and generate Physically Based Rendering materials in one click. - Object Painting
“Paint” accessories (e.g. table decor) or randomly scatter trees, bushes, etc., directly onto scene surfaces. - Batch Import/Export
Import or export multiple files at once to streamline large-scale workflows. - Asset Tracking Management
- Quickly locate and resolve any missing file references.
- Reassign broken links and gather all referenced assets into a single folder.
- Batch Utilities & API Extensibility
- Batch image conversion, batch render & relink, and batch-rename files using wildcards or masks—supports diacritics replacement and Cyril→Latin transliteration.
- Extend Project Manager via its API with included code samples.
What´s New
- Project Manager 4.01.88 — The Library That Remembers What You Searched For: Save searches as categories, assign icons in one click, and treat archives like folders
- Project Manager 4.01: The Asset Browser That Understands You: AI Text Search in Over 30 Languages, Search by Image, Localised Interface
- Project Manager 4 — AI asset classification is here: AI Sorting, Colour Search, Find Similar, Local & Fast
- Project Manager 3.41 — Features You Requested: Online Licenses, Merge from Archives, Personalize Colors
- Project Manager 3.40.00 — Instant Search: Instant Search & Blazing Fast Navigation
- Project Manager 3.38.10 with 3ds Max 2026 Support: Bug fixes and performance improvements
- Project Manager 3.37.41: Custom Icons and Quick Access Recent Assets: Bug fixes and performance improvements
- Project Manager 3.36.40 Release: Key Updates and Improvements: Customizable Interface & Hotkeys | Support to USD
- Version 3.35.75: Enhanced Asset Organization and Management
- Version 3.35.25: Enhances Asset Tracking Management for 3D Models and Materials
- Version 3.23.05: Bug fixes and performance improvements
- Version 3.20.02: Bug fixes and performance improvements
- Version 3.18.72: Speeds-up collect files on batch relink. Fixes some issues with HiDPI screens
- Version 3.18.34: Open the Material Libraries and 3Ds Max files in the Material Browser. Smarter Search for Preview Thumbnails
- Version 3.18.16: Templates for Physically-Based Rendering materials
- Version 3.17.46: Drag and drop Materials. Instancing 3D Models
- Version 3.17.26: Batch Archive. Speeds-up navigation
- Version 3.15.78: Batch Rename Materials
- Version 3.15.31: Dome Light. Search in Categories
Supported Renderers
Sweep Profile vol.1
Romas Noreika (verified owner) –
Great great tool for 3ds max. Does take time to set up you libs but once you do it its a blast to work with.
Thanks a lot, great to hear it’s working well for you. Setting up the libraries is a one-time investment that keeps paying off on every project.
Volkan Dinç (verified owner) –
Project Manager has become an essential part of my daily 3ds Max workflow. Managing models, materials, textures, IES lights, and proxies without it honestly feels unthinkable now.
What really stands out is how actively the plugin is maintained. It’s consistently updated, and whenever there’s an issue or a question, the support response is impressively fast and genuinely helpful. You never feel left hanging.
Browsing archives like normal folders, real-time previews, batch tools, and the overall performance make a huge difference in real production environments—not just demo scenes. It clearly feels like a tool built by people who actually use 3ds Max professionally.
Highly recommended for anyone serious about asset-heavy projects. Saves time, reduces friction, and just works.
Thank you so much for this wonderful feedback — it means a lot! It’s great to hear Project Manager has become a core part of your workflow.
Stay tuned — a new version is coming soon, featuring exciting AI-powered upgrade that will take things to the next level! 🚀
Fa Huynh (verified owner) –
This plugin save me a lot of time and easy to use. Many Thanks
Thank you!
We’re thrilled Project Manager is helping your workflow.
Happy creating!
Dart Design (verified owner) –
Best plugin for 3D assets and the best support ever!
Highly recommended!
Thank you so much for your kind words and recommendation!
Total “must have” in 3ds max! An add-on that completely changes the workflow and incredibly speeds up work. Managing assets or materials is pure pleasure if you use Project Manager. If I could give more stars, I would without hesitation :)
Grzegorz Mularczyk (verified owner) –
Project manager is great plugin. My job very boost now… Thank you for this plugin. Just i needed like this solution.
Thank you!
Your comments are appreciated, and we’ll continue working to make the plugin even better for users like you.
emmanuilkav (verified owner) –
Project manager is an essential tool that I have been using for over two years. It has significantly sped up my workflow and keeps all my assets well-organized. It is totally worth the investment, and I highly recommend it!
Thanks for your feedback! Happy creating!
Juan Pablo Estupinan (verified owner) –
This is just a small thank you to Oleksandr for the last update 3.37.17, it running great for us, librarys load so much faster, icons are a great addition !! ability to share icons and colors with the database and team..
Been using PM for at least 10 years and its better than ever :)
Thank you for your support and kind words!
🙌 We’re glad you’re enjoying the latest update and its new features. 😊
Sameer Nagar (verified owner) –
Great plugin
Krzysztof Levin (verified owner) –
It is one of the most advanced libraries I´ve ever seen and it is packed with goodies that help to save shaders and models and more….I really like it alot. Very useful and a must for any artist who takes himself seriously.
Thank you so much for your kind words!
Your support and feedback mean a lot to us.
Keep creating amazing art!
esam da (verified owner) –
Most great plugins. help to fasten the project. Very glad to use it
Thank you
Project Manager is definitely one of the plugins you want to have in your set of tools. It is not only a time saver, but also a perfect library organizer. Thank you!!!
Glad to hear you’re enjoying Project Manager!
Thanks for the feedback!
Kostas Geranios (verified owner) –
One of the most useful plugins for 3ds max. Stable enough, it could be a little bit more customizable. Worth buying 100% though.
Thank you for your feedback! We’re glad you find it useful!
niknok47 (verified owner) –
Great Plugin! A must for 3dsmax user.
Thank you so much for your kind words! Happy creating!
Chad McDonald (verified owner) –
Essential plugin for any serious Max user. Updates are quick and support reliable. FIlls a neglected gap in Autodesk development. Use it everytime I open the program.
Thank you for the high praise!
We’re delighted to be a key part of your Max toolkit.
It is definitely very useful, it speeds up the workflow incredibly. The interface is very easy to use. I definitely recommend it. I would also like to thank those who developed the product.
We are pleased to hear that the plugin has significantly sped up your workflow and that you highly appreciate the interface. Your feedback means a lot to us.
pstros (verified owner) –
One of the best plugins for 3ds max. I use it every day.
We’re thrilled to hear that our plugin has become a daily part of your workflow with 3ds Max.
Thank you!
Samer Serhal (verified owner) –
That is so efficient, i hope you keep developing it
Jesus Velazco (verified owner) –
Absolutely a most to organize libraries, from 3d models to textures. The tool to create renders for the thumbnails is amazing, I used it to generate previews for a project with a bunch of assets and share them to my client. Time saver
We’re delighted our tool has been a time-saver for your projects.
Keep creating and sharing!
j.a.b (verified owner) –
Indespensable tool for any serious viz-artist. I cannot imaging how much time this tool has saved me. Support and bug-fixing is extremely fast.
nateclowar (verified owner) –
Quick and easy to use, already does exactly what I need and I haven’t even started using all the features yet.
Adele Qasim (verified owner) –
great tool !
Paul H (verified owner) –
Excellent product. I use this plugin everyday and it saves me soo much. I wouldn’t be without it.
Thank you for using. Glad to be helpful!
Machteld (verified owner) –
I heard of this plugin via ArchVizArtist.com and I love it, huge timesaver!
Zora Groothuis Arroyo (verified owner) –
Nos ha cambiado por completo el ritmo de trabajo, tanto a la hora de crear nuevas escenas como gestionar escenas externas, es maravilloso para tener tu biblioteca a un click de distancia y de un simple vistazo, y gestionar los assets de una escena. Lo hemos comprado ya 2 veces, y cuando necesitemos un upgrade lo volveremos a comprar
Bastian Robertino Galleani Cabrera (verified owner) –
excelente producto, cuando ya lo tienes configurado acelera tu producción de muy buena manera.
Kotaro Mori (verified owner) –
非常に有意義なプラグインです。大変時間の節約になります。
Thomas C (verified owner) –
Definitely a huge time saver, I highly recommend this useful plugin.
ABDNAF (verified owner) –
One of the most useful plugin, Must have!
Thanks KSTUDIO
兵 黄 (verified owner) –
very good production .i love it
The full version works very well and is very helpful to organize materials and scenes. It saves a lot of time. Very useful.
Richard Throgmorton (verified owner) –
I initially bought this ‘hoping’ it would help me consolidate a projects’ files into its main project folders. It wasn’t immediately clear if it was possible, but it seemed that the literature was stating something to that effect. If it did I was still looking forward to a few hours of work, but at least an hour or so would have been saved. (Stuff was scattered on different network drives.)
I install, restart Max, test the Project Manager to make sure it will work, load my scene, and attempt to consolidate.
Overall it took about 20 minutes to get started, test, and run the tools to do the work. Maybe 30 minutes passed, maybe, and all files were copied into the correct folder, the sweet little PM relinked the textures to the materials (holy mother of beer, it worked), the project was packed, and it was uploaded to the file drive for the client.
I literally saved HOURS of work on that one single operation. The stress I usually feel of having to do that manually just washed away. It’s not possible to regret purchasing this plugin.
Glad to be helpful to you and thanks for your story!
Komodo (verified owner) –
One of the most useful plugin.
Must have!
LeXuanFX (verified owner) –
非常好用的一款插件,使用它可以轻松管理各种3dsmax资源、能够节省很多时间!期待发布中文版
Abderat Qias (verified owner) –
he best timesaver for working in 3dsmax
I have come across! I have to kick myself for not buying it earlier. After only two days use I can’t manage without :-)
Semiha Karatas (verified owner) –
A great time saver! We use it, especially for material collections and management and it is very useful
Alejandro Gonzalez Romo De Vivar (verified owner) –
A must have tool for 3dsmax everyday users. The new advanced asset renamer is a time saver!
Roberto Albinati (verified owner) –
Es un producto que me facilita y agiliza el trabajo, es muy útil, organiza y optimiza mi tiempo, excelente, lo recomiendo ampliamente!!!
Uno de los mejores complementos para 3d Max.!!
Erdenebayar Minjuur (verified owner) –
Very very useful plugin! Amazing! Thanks KSTUDIO
D0br0 (verified owner) –
At first I was skeptical about this product. But after trying it, I really liked it. Now I actively use it.
Jonas Noell (verified owner) –
Can really recommend this very helpful plugin. Helps a lot with keeping your whole asset library organized and has many helpful additional functions!
Gordon (verified owner) –
I use a while with the demo version, it was a great help for my assets organization. Good job!
Mauricio Cavalla (verified owner) –
Project Manager is an incredible plugin that not only helps you organize your libraries, but it also has many more powerful tools to work smoothly and optimizing time for your projects. Now that I use it, I wouldn’t know how to go back without this tool.
Terje Hamnes (verified owner) –
The best timesaver for working in 3dsmax
Thanks for your review.
Nice to be helpful!
mochinaga (verified owner) –
Project Manager is a very good 3ds Max script. It will definitely be one of 3ds max’s best plug-ins. By introducing it, work will be much faster.
It’s a complete plugin, but I personally want it.
・ I hope the font looks big for 4k monitors.
・ I want a function to close the project manager with the cross button.
(Because the file display may not be reflected.)
・I want you to support double-clicking to open a file.
When organizing files, I made several mistakes in saving when merging.
Thanks for your review!
– Use the menu item “Exit” for closing the plugin.
The cross button hides Project Manager.
Jose Miguel Perez Colon (verified owner) –
Project manager is a stunning plugin for organize your CG library. It’s like a ‘Lightroom’ for 3ds max users because you can keep organize your 3d models, HDRI, Materials and texture of easy way. The plugin runs in a separate window that you can see all yours assets and it’s very useful to choose the correct models, also have a extra tools that help to insert very handy in your 3ds max scene.
Project manager it’s robust, intuitive, useful and necessary for your 3ds max workflow. The customer support it’s 5 stars, Alexander Kramer will attend your ask in short time. And for what not to talk about the price is super fordable. For what reason I putted a excellent review? It’s because I be totally satisfied with this product.
I recommend Project Manager to all 3ds Max users!
Fateh Alsam (verified owner) –
Amazing
Oscar TUNG (verified owner) –
high recommended
Thank you for your contribution.
Some of the fixes and features of the latest version appeared thanks to your feedback.
Osvaldo C Nevot - Co-Founder of Cuban Spartan Studio (verified owner) –
The life of an indie studio is not possible without this product. It has simply changed the speed and structure of our studio. There is nothing like it.
We strongly believe that every artist or studio on the planet should have this piece of software.
Thank you! Glad to be helpful for you!
jeanphi (verified owner) –
It is a necessary tool for organizing projects! I’ve tried other similar tools but Project Manager works best!
Marcio Santos (verified owner) –
Best project Manager tool on market that we know. We have researched a bit, including some famous tools, and this one is by far the most simple and complete.
Thank you!
Edson Sanchez (verified owner) –
Definitely an indispensable tool. I have discovered elements of my library that I never used because they were not well cataloged and thanks to project manager I have started to have everything under control. The best thing is that it still has room for improvement and is constantly updated. Very happy with the acquisition.
David Sáenz De Ynestrillas Vera (verified owner) –
I will not exaggerate, it is a great plugin. I bought it recently but I already use it in every project I do.
It really speeds up my workflow and makes the tedious process of maintaining the library of objects, maps, materials even fun.
The only thing I regret is not buying them before.
Man Mars (verified owner) –
Managing asset is one of the most important thing with a 3D artist. Well managed asset helps you work much more effective. And this tool can help you to do that with its powerful functions and easy to use. Plus supporting from the developer is very good. Recommand!
Hi, Man! Thanks for the great comment!
We are very pleased and important to know what you find Kstudio Asset Browser useful.
Tryharder (verified owner) –
Takes a while to understand all the features. But after a while it rocks.
That´s a real time saver. A must have plugin!
Jixal (verified owner) –
Fantastic plugin! Works effectively and efficiently. Easy to install and setup. Makes managing & using asset & shaders libraries intuitive and easy.
This is something that should be natively included in 3DS.
Thanks for your words, Jixal!
Hope you will also like 3rd version.
PS. Development of 3rd version now at the final stage.
And will be available in month or maximum two.
Mohammad Nabil (verified owner) –
for me, I’m very happy to get powerful script help me to work very fast more than ever
shawnolson (verified owner) –
Total must-have tool. I love it.
路明 陈 (verified owner) –
The first time I used this software, it improved my efficiency in CG work. I am a CG worker from China. Can you develop multilingual versions?
Multilingual version in my wishlist.
Tristan Hung –
It’s one of the best plugin for 3Ds Max you can get !
but not sure is there any other way you can create like shortcut links in Windows, show model thumbnail in couple different folders but only save the whole model asset once in a folder?
Thank you
I have been working on Archviz for longer that I can even remember, through times I have used many asset management tools, both free and paid, even tried to implement workflows that would allow for easy management, and none of those practices come even close to what KSTUDIO’s Project Manager has to offer, plus the state of the art customer service that Alexander offers.
Marco Andrade (verified owner) –
I havent used it a lot since I bought it a few weeks ago, but it is fast and better than browsing in the normal windows explorer, I still have to understand how to add all my libraries. I will keep looking in the manual. Great plugin so far!
Thanks for for your feedback, Marco!
Hope what next links will be useful for you:
Here you can find a videos about working with Project Manager
Videos about using the Project Manager
Tutorials
And
Frequently Asked Questions
Chris Wade –
I have used Project Manager for a few Years now, and although it can be buggy at times, the Positives out weigh the Negatives massively, I would like to see it be able to Run Faster loading thumbnails generally etc, I would like to see a MOVE Textures option for assets, instead of always COPYING, but that’s a minor thing, unless it does that already and I have missed it.
I would like better control on Thumbnail rendering, doesn’t quite work as you would think always.
But generally It’s Great, well done to the Team
Daniel Diaz Del Castillo (verified owner) –
A must have for any office size, PM is in the heart of our daily workflow, and the customer support is out of this world! Must buy!
Gustavo Ratner (verified owner) –
llevamos pocos dias usando el Project Manager, pero en principio nos parece un Excelente producto. 100% recomendable!!
Torri Walter (verified owner) –
Uso questo prodotto da più di 5 anni e questo è il secondo Project Manager che acquisto.
Un prodotto indispensabile nel lavoro 3D.
Grazie anche al continuo aggiornamento svolto
Dal nostro Alexander Kramer.
Rodrigo Aldeabaran Diaz Maldonado (verified owner) –
hasta el momento que lo he ocupado es fantástico es muy bueno y recomendado 100%
Sérgio Merêces (verified owner) –
It helps us a lot in several tasks and get our stock models organized and ready to populate our scenes. Keep improving it and for sure we will get a really great tool
Joe (verified owner) –
Used for several years, is one of the best plug-ins I’ve ever used. Very practical and convenient at work.
If can add a library management script is even better.
Clark Bickford (verified owner) –
Inserting models is very difficult compare to Asset Browser, and not from a learning curve, from a software point of view. It’s slow, glitchy and not great at picking or placing objects compared to other tools we have used.
The program has quite a lot more features, but can be unstable and requires lots of updates to fix bugs. It’s getting better but still needs quite a bit of work to make it worth the asking price. It lacks the feature to add a thumbnail from clipboard or file easily, it’s quite a manual process to add a model and thumbnail compared to HCGAB. This additional time adds up in a production envrionment.
All in all, not a bad program that will only get better with improvements/time.
Thank for your review.
Please describe more about issues with inserting models and other issues what you receive using Project Manager.
About the purpose of assigning custom thumbnail to files – the next version will be able to use a custom preview and be able to specify several related files.
P.S. I would be grateful if you could post a description of your wishes and bug reports on the forum. As a rule, most of the errors are resolved within a week if there is sufficient information from users.
Warren DeBruyn (verified owner) –
Probably one of the best thought out plugins, fast and reliable, easy to use and very convenient. It makes populating a scene very easy!
Brian Chapman (verified owner) –
My favorite plugin by far. There’s no comparison to the instant access and import options for everything needed (mats, textures, models, etc).
Nazarii Vovk (verified owner) –
It is just amazing! It has everything i need.
George Chianese (verified owner) –
Excellent for managing proxies. Easy to create thumbnails of your models. Was using connector app, but this is simpler to use.
Nicolas Balagny (verified owner) –
Our whole team has been using “Project Manger” for a year now. We can not imagine the daily work without this brilliant plugin. The developer is extremely close to the user and is very quick to answer questions
Michael Bilodeau Balatti (verified owner) –
I don’t know what i would do without this and each time i wonder why it doesn’t cost more$. Thanks!
Gary Tyler (verified owner) –
I have been blown away by the new Project Manager demo so I purchased it.
I had tested the past versions and while impressed, I did not purchase.
I expect this new version will become a popular must-have for every 3ds Max user.
Very excited to adopt this into my workflow!
Bob Emerson (verified owner) –
been using this for 5 years and every time I switch 3d max on (which is daily)
no problems at all, it keeps getting better and the support is great when I update my hardware and need to re-install and get a new license key.
alex is a top man.
John Santangelo (verified owner) –
I have been using Project Manager for about 3 years now. Can’t live without it. Powerful, easy to use and the customer service is unmatched.
Scheffold Christian (verified owner) –
Perfect.
Don’t sell it to Autodesk!
Rossen Mitov (verified owner) –
Very pleased with this product. It definitely saves me time. The support is great too. Highly recommended!
Project Manager streamlines the creation and maintenance of large 3D library assets.
I love using it and the customer support is great!
This is a tool that I will never do without!
Tarek SAADE (verified owner) –
I used this tools a lot everyday, usually finding, relinking or copy images are time consuming,
but PM helped me to do it as fast as possible with one click.
I think many people do not know what treasure it is, so I recommended everybody to try at least one time.
Thank you so much for this great tools.
Albert Chan (verified owner) –
Excellent software. Customer support is awesome.
Mustafa Mamdouh –
One of best products for 3ds max I have ever seen!
Nicolas Bischoff (verified owner) –
The best asset browser available.
Our entire studio uses this and it was worth every penny.
Peter Letten (verified owner) –
Great product by the way!
Its totally integral to the way I use max.
IFan Juang (verified owner) –
“Project Manager” has been made a considered impact in our organization of files;
especially at the final phase of a project, when we are pressed for time and where all the small enrichment (models, materials, lights) in the 3d scene make all the difference in the final render.
