Viewing 15 posts - 16 through 30 (of 37 total)
  • #30470
    Pureblink Server
    Threads: 5
    Hi!
    We are using version 3.13.07
    Thanks for the quick answer.
  • #30472
    Please generate the bug report.
  • #30474
    Pureblink Server
    Threads: 5
    Will do, thanks
  • #37676
    Eduardo Javier Miranda
    Hi team, quick questions can MySQL be used to sync databases on a nonlocal network? Example trying to sync or database with our users in another country.
    We tried moving the database into a dropbox folder that syncs in both countries.
    • #37677
      SQLite database doesn’t support such use – it can be used only as a local database. SQLite database will be destroyed periodically in your case.
      You should use MySQL or MariaDB database.
  • #37686
    Jai Eakin
    Hi, I’ve setup a MySQL server on AWS and can connect to it fine from both inside the customize->preferences->database tab and also from mysql workbench.
    however when I click “copy database” – “copy from SQLite to MySQL” then click “Apply,” (it thinks for a little while), then I convert paths to network as per the above tutorial and then click close but my library disappears? Everything in Models/Textures/IES is gone.
    If I switch back to SQlite then the library is back from the local database.
    Are there extra steps I need to follow for getting this to work via Amazon cloud?
    Does copying the database in this instance actually send it to the cloud?
    Extra info: Our team are all remote workers. We all sync the same library assets via box.com to a network path Y: drive.
    • #37689
      It should work. Check database logs
  • #37732
    Tikaradze Arsen
    Threads: 4
    Hello
    When i am connecting to server i recive error:
    I installed this software:
    • #37749
      Tikaradze Arsen
      Threads: 4
      I used software version 8.0.30
      Now i am reinstalled all software version to 8.0.28.
      I I chose not to install any Visual Studio or Python Connector  which is asking during installation.
      This solved my problem
  • #38684
    Daniel Diaz Del Castillo
    Threads: 21
    What Version of VIsual studio is everyone using now ? Microsoft has put behind a paywall all  visual studio versions, i can download the community version but the sql installer wont recognize it..
  • #41698
    Jerome Romero
    Threads: 4
    Hello,
    We cannot get PM Teamwork mode working.  Folders and Catagories disappears in Teamwork mode.
    -We all have PM Full Versions
    -Followed aboves step by step instructions
    -MySQL Test connection successful
    -MySQL user all have Adminstrative rights
    -Import Database from SQLite to MySQL popup says successful -No Models or Material folders/catagories shows up in ‘teamwork mode’
    -I’ve hit refresh and checked show hidden folders
    -I’ve tried on Win10 MySQL Server v8 port3306, and Maria DB (HeidiSQL v12) port3305. On Win7 v5.7 port3307
    Workstation Windows 10 & 11, 3ds Max 2024, Project Manager 3.35.26
    What else can I try?
    We need to have Teamwork working to sync our material & model catagories. We are former Connecter users and now going to use PM.
    Thanks
    • #41699
      Jerome Romero
      Threads: 4
      • #41701
        MariaDB server supported from version 10.3 up to 10.8
      • #41702
        Check also, if SQLite database is not empty.
        Try to add a few directories manually and refresh the directories list.
    • #41708
      This issue has been fixed.
      This was due to a database imported from Connector.
      Just download and install the latest version.
