- November 23, 2026 at 09:37 #48391
15810142059aParticipantPosts: 4Threads: 9Joined: Mar 2025Hello,
I found a bug and would like to request a fix.
When a single texture file is dragged into the Material Editor, the material is recognized and assigned correctly. However, when multiple texture files are selected and dragged in at the same time, the material is not set up correctly.
Please check my screen recording: YouTube Video https://youtu.be/Ydg9eoWAeSs
Plugin Version: 4.02.87
3ds Max Version: 2026Thank you.
Plugin version: 4.02.87
3ds Max version: 2026
Renderer: arnold - November 23, 2026 at 16:54 #48393
Oleksandr KramerModeratorPosts: 269Threads: 1414Joined: Aug 2009Hi,
Thanks for the report and the video.
Currently, the Default Material list only defines which material is used when creating a material from a single texture. For PBR texture sets, the template defined in the Material Templates dialog is used.
**Workaround for the current version (4.02.87):** create your own PBR template.
1. Open Preferences → Textures and choose “Edit Material Templates” in the material list.
2. Build the template with a Physical Material for your renderer (Arnold) and save it.
3. Dropped PBR sets will then use that template.
Create Physically-Based Rendering materials with Project ManagerIn the next version, we will add an option, “Apply also for PBR Materials”, under the Default Material list.
When it is enabled, the material selected in the list will also be used when several PBR textures are dropped.Best regards,
