  • #47509
    Daniel Diaz Del Castillo
    Threads: 21
    So we all know that 3dsky previews are a mess, some authors create the preview along the max file, sometimes with the numbers name, and other with the furniture piece name, what i need is the ability for Auto-Assign Previews to search for a pairing between the folder (and subfolders)of the 3dsmax file and the preview with the  numbers name or max file name.
  • #48313
    Threads: 1414
    Thank you for pay attention to make Auto-Assign Previews could do better.
    This is already implemented in the new version.
    Most previews are now found, even in tricky cases where the preview name doesn’t match the model.
    If nothing matches by file name, the tool can fall back to:
    • Images that are not textures in a single-model folder, filtered by a configurable subfolders mask (preview, thumb, render, etc.)
    • Previews extracted from a PDF catalog
    • The case you described (a single model folder with a _RenderPics subfolder holding one preview with a hash-like name) is handled too: the preview is found and assigned to the .max file in that folder.
    What’s new in the release notes:
    Automatic Preview Assignment
    • New smart preview assignment: matches models to files more intelligently and extracts previews from PDF catalogs
    • The result window now shows how many files were processed and how many previews were assigned, including files with no preview found
    • Assigns previews faster across large folder trees
    Please update and try it on your library. If some packs still end up without a preview, send me an example of the folder structure and I’ll look into it.
