- March 21, 2026 at 16:56 #46675
Michal ZiobroParticipantPosts: 22Threads: 43Joined: Mar 2015After install update i got this error:
— Error occurred in anonymous codeblock; filename: D:\Documents\2022 – 64bit\scripts\startup\ProjectManager_3.ms; position: 426; line: 12
— Unable to convert: undefined to type: FileName
— MAXScript callstack:
— thread data: threadID:33012
— [stack level: 0]
— In execute(); filename: D:\Documents\2022 – 64bit\scripts\startup\ProjectManager_3.ms; position: 427; line: 12
— member of: codeblock macroScript: Kstudio_Project_Manager_3
— Locals:
— msg: undefined
— startDirectory: undefined
— formName: undefined
— assetForms: undefined
— FilePathFinderProForm: undefined
— FilePathFinderLightForm: undefined
— MaterialsManagerForm: undefined
— ModelsManagerForm: undefined
— FilePathFinderPro_4Form: undefined
— FilePathFinderLight_4Form: undefined
— MaterialsManager_2Form: undefined
— ModelsManagerForm_2: undefined
— Externals:
— ProjectManager_3Form: Global:ProjectManager_3Form : undefined
— ProjectManager_3Open: Global:ProjectManager_3Open : undefined
— owner: <CodeBlock:Kstudio_Project_Manager_3>
— Kstudio_Project_Manager_3: <CodeBlock:Kstudio_Project_Manager_3>
— g_KstudioInstallProjectManager_3: Global:g_KstudioInstallProjectManager_3 : undefined
— [stack level: 1]
— called from codeblock macroScript: Kstudio_Project_Manager_3
— Locals:
— Externals:
— [stack level: 2]
— called from top-levelThank you for help
- March 21, 2026 at 16:56 #46677
Oleksandr KramerModeratorPosts: 269Threads: 1413Joined: Aug 2009You haven’t mentioned which version of Project Manager you installed, but based on the error it looks like an older version may have been used.
Please download and install the latest version from your account downloads page:
https://3d-kstudio.com/my-account/downloads/ - March 22, 2026 at 03:13 #46678
Michal ZiobroParticipantPosts: 22Threads: 43Joined: Mar 2015I donloaded it. PM works only first time after install.
Sorry for that. I use 3ds Max 2022
- March 22, 2026 at 17:07 #46679
Oleksandr KramerModeratorPosts: 269Threads: 1413Joined: Aug 2009Hi,
It looks like the file %localappdata%\Autodesk\3dsMax\<ReleaseNumber> – 64bit\ENU\Plugin.UserSettings.ini is not accessible, although this file should be available by default.
Please check whether the entry “Kstudio Startup 2022” exists in that file and what value it has.
- March 23, 2026 at 06:20 #46680
Michal ZiobroParticipantPosts: 22Threads: 43Joined: Mar 2015Kstudio Startup 2022 – no such entry
- March 23, 2026 at 17:07 #46682
Oleksandr KramerModeratorPosts: 269Threads: 1413Joined: Aug 2009In that case, access to that file appears to be blocked.
As a quick workaround, close 3ds Max and manually add the following line to the file:Kstudio Startup 2022=C:\Users<Username>\AppData\Local\Kstudio\data\startup\2022\
However, the better solution would be to resolve the underlying access issue, as this file should be accessible by default.
This is typically caused by overly restrictive permissions set by antivirus software or Windows security policies. - March 26, 2026 at 05:15 #46695
Michal ZiobroParticipantPosts: 22Threads: 43Joined: Mar 2015Alex
I did. Even mannualy added path didnt work:(
- March 26, 2026 at 13:13 #46696
Oleksandr KramerModeratorPosts: 269Threads: 1413Joined: Aug 2009Please send this file to me (support@3d-kstudio.com) and check your directories for hidden/system flags
https://3d-kstudio.com/support/faq/#42540
