  • #45933
    Thomas C
    Threads: 47
    When I install latest Project Manager, I get the following error:
    Installation failed.
    — Runtime error: .NET runtime exception: Access to the path ‘Dirt03.jpg’ is denied. (‘oahokYWfl6JbJwbNxY7SXA==’)
    Can you help?
    Thank you
    Plugin version: 3.45.21
    3ds Max version: 2023.3.7
    Renderer: Corona 10HF2
  • #45940
    It seems that a file named Dirt03.jpg somehow appeared inside the Project Manager installation folder and is currently locked by the system.
    To fix the issue, please delete that file manually.
    Here’s how to do it:
    Close 3ds Max.
    Open File Explorer and paste this path into the address bar:
    %localappdata%\Autodesk\3dsMax\<version> – 64bit\ENU\scripts\Kstudio\ProjectManager_3\
    (replace <version> with your 3ds Max version, e.g. 2025)
    Locate the file Dirt03.jpg.
    If Windows says the file is in use, restart your PC and then try deleting it again.
    After deleting the file, reinstall Project Manager.
    That should resolve the problem.
  • #45949
    Thomas C
    Threads: 47
    All good now, thank you.
