- December 9, 2019 at 15:47 #23853
ModeratorPosts: 264Threads: 1283Joined: Aug 20091. It would be super helpful, if an object was automatically assigned to a favorite once it was assigned to a subfavorite.
Soon Favorites will receive the ability to show files in subdirectories. So you will able to watch files in subcategories.
2. Choose any favourite from list.
Thanks for idea – I’m adding this to wishlist
4. … So you can have two or even more thumbnails generated by PM.
PM allows linking multiple thumbnails to one asset during batch rendering.
Also as I understand you want what last rendered thumbnails used for default preview instead existing preview. But existing preview must also keep in the asset’s gallery. I think that this is also possible.Thanks for your ideas!
- January 8, 2020 at 11:32 #25156
Holger Drechsler
ParticipantPosts: 1Threads: 1Joined: Apr 2018Very interesting to read the wishlist. In the answers of Alex I learned something new about Project Manager. My wish would be a help file, which holds more information. The current one is more or less a list of features and functions. I would like more information because not all of the user interface is self-explaining.
Another wish: In the Material browser you see some information for the selected material on the bottom of the windows (name, type, bitmaps…)
Could you please add some information on the saved modifiers? Thanks a lot for this great utility!
- May 7, 2020 at 21:45 #27825
Edson Sanchez
ParticipantPosts: 0Threads: 8Joined: May 2020Favorites in alphabetical order please.
[Resolved]
- May 7, 2020 at 21:48 #27826
ModeratorPosts: 264Threads: 1283Joined: Aug 2009You can order Favorites manually using CTRL+UP/DOWN keys
- September 16, 2020 at 15:33 #29534
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Favorites in alphabetical order please
Support since version 3.12.17
- May 7, 2020 at 23:03 #27827
Flavio Martins dos passos
ParticipantPosts: 0Threads: 4Joined: Apr 2019Very good ! Aproved
- May 7, 2020 at 23:04 #27828
ParticipantPosts: 0Threads: 4Joined: Apr 2019I would find excellent tutorials on how to organize the library and look for lost maps, this would help the user a lot.
- May 8, 2020 at 12:14 #27831
You can find tutorials on Kstudio’s Youtube channel
This is a new video-list with latest tutors
- September 13, 2020 at 21:57 #29477
Nuno Moser
ParticipantPosts: 6Threads: 3Joined: Mar 2018To be able to see on the library what modifiers have a certain material.
[Resolved]
- September 14, 2020 at 19:31 #29494
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Thank you for your idea.
Add this feature to the wishlist
- September 14, 2020 at 13:37 #29482
Patrick Gavin
ParticipantPosts: 0Threads: 1Joined: Dec 2016loving the auto create material from dragging in a bunch of textures to the slate material editor.
This is a real timesaver when creating pbr materials.
As you are support vray bitmap in vray 5 would be nice to have the material auto build by using for example the diffuse map as the mapping source to drive the tiling of the other bitmaps. They will have the same tiling in most cases.
This video shows what I mean at about 4 mins 30 seconds in.
There are also some other good randomisation tips in there that might be good to auto create.
Thanks for all the good work.
[Resolved]
- September 14, 2020 at 19:28 #29492
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Thanks for the great idea!
I’ll add this feature to the nearest version.
- September 16, 2020 at 15:30 #29533
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Done!
Try version 3.12.25
Now Project Manager supports mapSource for V-Ray PBR materials and displays a list of modifiers linked to the material.
You can download it from the dashboard.
[Resolved]
- September 15, 2020 at 04:44 #29514
seam Huang
ParticipantPosts: 1Threads: 3Joined: Aug 2020show directories in the listview
- September 19, 2020 at 21:34 #29588
Edmar Cortez
ParticipantPosts: 0Threads: 3Joined: Sep 2020Hi Alex
When im re-saving a model, from the explorer the save/export selected window give a object name saving option, so if i want to replace my model i have to copy the name from my file in the folder so i can re render the thumbail with the new changes, is it possible to put on the file name, the actual name of the file so it automatically replaces it?
[Resolved]
- September 21, 2020 at 14:52 #29592
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Maybe you mean a function like replace/update selected file ?
- September 22, 2020 at 15:33 #29605
Edmar Cortez
ParticipantPosts: 0Threads: 3Joined: Sep 2020YES! Exactly i didnt know how to explain it .
- September 22, 2020 at 15:38 #29606
Edmar Cortez
ParticipantPosts: 0Threads: 3Joined: Sep 2020I dont know if its already on the software?
- September 22, 2020 at 16:06 #29607
- December 4, 2020 at 18:00 #30416
Steen Iversen
ParticipantPosts: 1Threads: 2Joined: Apr 2019Hi Alexander,
I cant read everything. So I am sorry if that you have it answered.
Can we have simple fast merge. Just like 3ds max merge but to select all objects and place them in a group in the 0.0.0 . The standard merge needs to do more clicks and regular merge is slow with big files .
Would that be possible – like Fast Merge or Speed Merge option .
Tnx,
Dobromir
Kompan
- December 4, 2020 at 20:09 #30423
ModeratorPosts: 264Threads: 1283Joined: Aug 2009I answered in your post
https://3d-kstudio.com/forum/project-manager-support/fast-speed-merge/#post-30421
- March 26, 2021 at 23:16 #31582
Paulo Rosario
ParticipantPosts: 0Threads: 1Joined: Mar 2021Hi Alexander.
So, I’d like to ask if there is any way to force Batch&Relink to save elements when generating thumbnails.
Here’s the thing:
As a 3D modeler, I’d like to use Project Manager to keep my models organized, but I’d also like to use it to generate preview images from several models without to have to open each file.
I know that’s perfect possible to render files right now, but there’s no way to save elements too.
So that’s why I’d like to have a way to save elements together, so that I could make some adjustments later.That product (https://www.splinedynamics.com/product/overnight-batch-render/) has the ability to save the elemets and so on, but I’d have to open the file, place the light setup, place my model, decor stuff. The only thing this thing automate is to render several files and save elements.
Batch&Relink is a lot more powerfull, since I can set a custom studio setup to render my files.
I know that’s not the main function for wich you product where developed.
But I’d like to know if you could add this funcions:
Save Elements and save those files in a specific path. The name of files should be get by any atrributes (object name, for instance).Would it be easier to add by script?
- March 30, 2021 at 15:16 #31611
ModeratorPosts: 264Threads: 1283Joined: Aug 2009This feature can be added using API
Create render-preset with desired render-elements and add the script for setup desired paths to files.
if BatchPostScript != undefined and BatchPostScript.GetMode() == #BeforeRender do (
/* turn on render-elements */
/* set desired path to render-element */
