Viewing 15 posts - 31 through 45 (of 182 total)
  • #9583
    Robert Stephenson
      Hi Alex, would it be possible to add more options when creating a vray proxy through project manager. I’d really like to be able to use objectID’s in vray proxies to be able to turn specific elements on and off, which it doesn’t seem to do at the moment.
      Thanks!
  • #9584
  • #9585
      arch3d said
      1) I can’t get this information dynamically. This requires opening the scene.
      But you can add this manually on the “Description” panel.
      Understood. So maybe it could work in batch mode. New menu command “get file info” could be useful. Its a hard work if I buy some model collection and I have to check e.g 30 files. I am looking for some idea how to automate it.
      Or maybe it could be on of creating thumbs options.
      Now you can read and write a custom description using the Project Manager API.
      Read more about new version of Project Manager.
  • #9586
    Michal Ziobro
    Threads: 40
      Alex,
      Many thanks for update xrefs work perfect.
      I also tried to set-up post-open script (i just copy example that you wrote) and i have seyntax error:
      “– Syntax error: at bad, expected <factor>
      — In line: format “%
      Once again great update
      Thanks
  • #9587
      This is a problem with web quotes )))
      Use the script “BatchRendering Script Example.ms” from directory “ProjectManager\presets”
  • #9588
    Michal Ziobro
    Threads: 40
      Thx, no errors now, but it doesnt wor for me:)
      File info shoud show in comment box?
      Maybe you could post some screen :)
  • #9589
      Save file’s description
      Save file
      Display file’s description
      Display file
  • #9590
    Michal Ziobro
    Threads: 40
      Ok i made the same,
      dunno why i got Batch R&R v.1.54.02 after update
      Sorry for problem.
      BTW can i add bounding box dimmensions to script? :D :D
      Cheers
  • #9591
      You must know the maxscript for using API.
      Also i can write it for you.
      Please send a details about script to email support@3d-kstudio.com
  • #9592
    Michal Ziobro
    Threads: 40
      Thank You!
      I dunno API (i can read it, but dont know syntax and actions:P)
      Ill spam your mailbox:)
  • #10921
    MariuszKolo
      It would be greate if you will add in HDRI category to import HDRI (create) Vray dome light with selected map.
      Thanks
      Mariusz from Storyline
      ref
      [Resolved]
  • #10933
      Thanks for your idea.
      Now you can assign HDRI to desired slot of Vray Light by dragging.
  • #11550
    Oleg Budeanu
    Threads: 2
      Thanks for including my idea in the wishlist !
      I am working now with the latest project manager version and i have another idea related to Favorites. Since you included the drag and drop .max files into favorites catalog (awesome feature!) – it would be a good idea to check for duplicates of dropped files, as file names could be different but with the same model inside. At least to check hash of the file or it’s size and warn of possible duplicate. And an option in settings to turn it off/on.
  • #11961
    Mats Ottesen
    Threads: 5
      Hi.
      I find the HDRI viewer a bit slow. I think its the thumbnail generating part.
      If the HDRI is really large it will take some time for Project Manager to generate the thumbnail and the process gets slower.
      It would be nice to have the option to “Create Thumbnail” for the HDRI and EXR images. So you can create a jpg of the HDRI. And innside Project manager the thumbnail will use the jpg instead of generating one on its own.
      I think that might help speed thing up. Especially when you have ALOT of large HDRI’s
      anyway its just an idea :)
      Best Regards
      -Mats
  • #11962
      HDRI and all large images always use caching.
      After generating preview the thumbnail saving to cache.
