  • #1825
    Threads: 1285
      FilePathFinder PRO v.3.2.33
      Adds support for Max 9SP2
      Sweep Profile v0.67
      Adds ability for Scale section
      Convert to Base Object
      Adds ability for convert multiply selections with saving Instance link (see small video)
      Add to Pack the new script:
      Render Preview (beta-version 0.74)
      Utility for making preview thumbnails for 3ds Max scenes, Material Libraries and IES files
      It also included to FilePathFinder PRO
  • #9512
    Threads: 1285
      Select by Material – fixes a bug for max 2010 & 2011
      Select by Material
      Script fo select objects with Material or texture from Active Material Editor Slot
      • By default will be select only visible objects
      • You can use Shift key for select Hidden and Frozen objects
      • With Control key you can add new selection to current selection
      FilePathFinder PRO
      FilepathFinder PRO v3.2.64
      • Fixes issues with cancel dialog for 3ds Max 2011 when run collect Asset Files.
      • Fixed issues with cancelling Collect Files operation.
      FilepathFinder PRO v3.2.61
      • Fixes some issues with working in not saved 3ds Max file
      • Fixed a bug with Vray SP5 and above where in the list of texture files were shown Render Output Files
      FilePathFinder Medium
      FilepathFinder(medium-version) v2.5.60
      • Fixes issues with the cancel dialog in Max 2011 when collecting Asset Files
      • Fixes issues with cancelling the Collect Files operation
      • Fixes the issues with collection the files without extensions
      FilePathFinder Light
      FilepathFinder Light v2.4.38
