- December 11, 2020 at 16:03 #30470Pureblink ServerParticipantPosts: 2Threads: 5Joined: Nov 2020
Hi!
We are using version 3.13.07
Thanks for the quick answer.
- December 11, 2020 at 16:07 #30472Oleksandr KramerModeratorPosts: 253Threads: 1062Joined: Aug 2009
Please generate the bug report.
You can find this option in the main 3ds max menu “Project Manager” ==>> Create Support Request. - December 11, 2020 at 16:31 #30474Pureblink ServerParticipantPosts: 2Threads: 5Joined: Nov 2020
Will do, thanks
- November 29, 2022 at 20:41 #37676Eduardo Javier MirandaParticipantPosts: 1Threads: 1Joined: Nov 2022
Hi team, quick questions can MySQL be used to sync databases on a nonlocal network? Example trying to sync or database with our users in another country.
We tried moving the database into a dropbox folder that syncs in both countries.
- November 29, 2022 at 21:44 #37677Oleksandr KramerModeratorPosts: 253Threads: 1062Joined: Aug 2009
SQLite database doesn’t support such use – it can be used only as a local database. SQLite database will be destroyed periodically in your case.
You should use MySQL or MariaDB database.
- December 1, 2022 at 07:35 #37686Jai EakinParticipantPosts: 0Threads: 1Joined: Sep 2022
Hi, I’ve setup a MySQL server on AWS and can connect to it fine from both inside the customize->preferences->database tab and also from mysql workbench.
however when I click “copy database” – “copy from SQLite to MySQL” then click “Apply,” (it thinks for a little while), then I convert paths to network as per the above tutorial and then click close but my library disappears? Everything in Models/Textures/IES is gone.
If I switch back to SQlite then the library is back from the local database.
Are there extra steps I need to follow for getting this to work via Amazon cloud?
Does copying the database in this instance actually send it to the cloud?Extra info: Our team are all remote workers. We all sync the same library assets via box.com to a network path Y: drive.
- December 1, 2022 at 12:24 #37689Oleksandr KramerModeratorPosts: 253Threads: 1062Joined: Aug 2009
It should work. Check database logs
- December 6, 2022 at 16:57 #37732Tikaradze ArsenParticipantPosts: 0Threads: 4Joined: Oct 2021
- December 9, 2022 at 13:53 #37749Tikaradze ArsenParticipantPosts: 0Threads: 4Joined: Oct 2021
I used software version 8.0.30
Now i am reinstalled all software version to 8.0.28.
I I chose not to install any Visual Studio or Python Connector which is asking during installation.This solved my problem
- April 18, 2023 at 18:32 #38684Daniel Diaz Del CastilloParticipantPosts: 16Threads: 21Joined: Jun 2017
What Version of VIsual studio is everyone using now ? Microsoft has put behind a paywall all visual studio versions, i can download the community version but the sql installer wont recognize it..
