- November 13, 2014 at 18:57 #9761
JoeParticipantPosts: 3Threads: 4Joined: Dec 2013I can’t drag and drop a .max format file.
Use shift-drop methop is ok. But it is not convenient。
*.3ds format is ok.
- November 13, 2014 at 19:58 #9762
Oleksandr KramerModeratorPosts: 267Threads: 1390Joined: Aug 2009Please generate the bug report (menu “Project manager” ==>> Create support Request)
Thanks for feedback.
- November 13, 2014 at 20:25 #9763
Jérôme GonsolinParticipantPosts: 1Threads: 2Joined: Feb 2014Same bug for me !
I’ve tried to generate the bug report but it fails to send the report (max script listener opens and say “can not merge”)…
Please help ! PM can’t be used at all !
Thanks!
- November 13, 2014 at 21:09 #9764
Oleksandr KramerModeratorPosts: 267Threads: 1390Joined: Aug 2009All right – i receive the report.
Please find me on skype: alexkstudio for faster solve the problem.
- November 13, 2014 at 23:19 #9765
Oleksandr KramerModeratorPosts: 267Threads: 1390Joined: Aug 2009Solution – change the state of the “Material Merge Options” to any another and back.
Or close the 3ds max and remove the ProjectManager.ini file.As a rule the path to scripts is located here:
“C:\Users\USERNAME\AppData\Local\Autodesk\3dsMax\20XX\ENU\scripts\TrackScripts\ProjectManager\”
Thank to Joe for help!
- November 14, 2014 at 12:54 #9766
Jérôme GonsolinParticipantPosts: 1Threads: 2Joined: Feb 2014ok, working now !
For me i had to completely erase “projectmanager” folder and reinstall it…
Thank you for the support !
Just another thing that as been probably already discuss: i can’t “directly” drag and drop rigged models (i get it without bones). It only work holding “shift” and choosing merge option… Am i wrong ? Is there another way to add rigged models in my scene?
- November 14, 2014 at 14:19 #9767
Oleksandr KramerModeratorPosts: 267Threads: 1390Joined: Aug 2009Hi, Jérôme.
Excellent.
I move the question about rigged models to new post.
- The topic ‘update V2 Can’t drag and drop files’ is closed to new replies.
