- May 8, 2019 at 14:11 #18196
Michal ZiobroParticipantPosts: 22Threads: 43Joined: Mar 2015Alex,
Can I control preview render by Corona noise limit? – for me doesnt work – Corona 3.0 :(
And second question – do You planning corona vfb support for rendering thumbs?
Best
Michal
- May 8, 2019 at 14:15 #18214
Oleksandr KramerModeratorPosts: 267Threads: 1405Joined: Aug 2009Can I control preview render by Corona noise limit? – for me doesnt work
Thanks for your question – I”l will check for this issue.
This also. If last corona version did receive some capabilities I’ll add this feature.
- May 19, 2019 at 23:06 #18266
Oleksandr KramerModeratorPosts: 267Threads: 1405Joined: Aug 2009Project Manager version 2.95.40 now supports to Corona vfb.
- May 20, 2019 at 07:56 #18267
Michal ZiobroParticipantPosts: 22Threads: 43Joined: Mar 2015Thank you very much
- June 19, 2019 at 19:35 #19694
Demetrio RuivoParticipantPosts: 2Threads: 6Joined: Nov 2017Hi Alexander, my Corona Renderer is not working with the corona VFB – Nor is the output from the default Max VFB saving things correctly to our library – is there an update coming to Corona 4.0? It will render, the thumbnail fine, but it is not saving and replacing the viewport generated thumbnail with the rendered one.
Thanks
- June 19, 2019 at 20:34 #19699
Oleksandr KramerModeratorPosts: 267Threads: 1405Joined: Aug 2009This is a bug in Corona 4
Corona 4 generates the exception on rendering start with simple maxscript command
bm = render vfb:false
You can report about this bug to developers.
- June 26, 2019 at 13:33 #19970
Oleksandr KramerModeratorPosts: 267Threads: 1405Joined: Aug 2009Corona Renderer 4 (hotfix 1) is released.
This version fixes a bug with rendering.
https://corona-renderer.com/download
- June 28, 2019 at 19:46 #19989
HypershadeParticipantPosts: 2Threads: 8Joined: Dec 2018Hi,
Corona hotfix 1 solved the problem of saving images. Now I have an another problem and a question.
It seems that Project Manager doesn’t doesn’t use the noise level limit from the .rps files. It doesn’t matter what limit I set, the rendering is always ends at the same/time, leaving me with very noisy thumbnails like this. This is with noise level limit 2%.
It worked before. If I use e.g time limit, it works, but obviously I can’t use the same time or passes for every material.
Do you have any idea what causes this?
And my question: how can I switch to the Corona VFB during thumbnail rendering, even if I render them one by one.
Thank in advance.
- July 1, 2019 at 12:30 #20007
Oleksandr KramerModeratorPosts: 267Threads: 1405Joined: Aug 2009This issue is fixed in version 2.96.23
You can download latest version from dashboard.
Auto-updater will be triggered in few days if there’s no critical issue found.
- July 3, 2019 at 13:46 #20111
HypershadeParticipantPosts: 2Threads: 8Joined: Dec 2018Hi Alex,
thanks it’s works perfectly well, Corona VFB also.
