- February 6, 2023 at 12:03 #38139
Rovi
ParticipantPosts: 1Threads: 2Joined: Feb 2023Is it doable or I should put folders anew?
Thanks
- February 6, 2023 at 12:09 #38143
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Use the Find&Replace option
https://3d-kstudio.com/tutorials/manage-asset-files-project-manager/#RelinkFindReplace
This option is also available in Batch Relink tool, which shipped with Project Manager
https://3d-kstudio.com/forum/batch-render-relink-news/batch-render-relink-v-2-00-00/#batch-relink
- February 6, 2023 at 13:01 #38144
Rovi
ParticipantPosts: 1Threads: 2Joined: Feb 2023Thanks for reply! You are referring to tools that change things inside the current max file.
And I’m talking about changing the path of the already existing folder(s) inside PM explorer (on the left side).
For example D:\models will be changed to \\computername\d\models so that in the future if I drag’n’drop files everything will be in UNC form.
- February 6, 2023 at 13:43 #38146
ModeratorPosts: 264Threads: 1283Joined: Aug 2009To relocating paths in the database you can use the “Convert Paths” tool
https://3d-kstudio.com/forum/project-manager-news/project-manager-version-3-07-91/
- February 6, 2023 at 14:12 #38147
Rovi
ParticipantPosts: 1Threads: 2Joined: Feb 2023Oh yeah Convert paths did exactly what was needed. Huge thank you,
Слава Україні!
