If the installer could not download the AI models automatically during installation,
you can download and install them manually.
Before unpacking the files, make sure that the AssetAI tray application is not running.
If its icon is visible in the Windows notification area, right-click it and select Exit.
Language models for AI-powered search
Download the archive for the language you want to use and extract all files into its destination folder.
Do not create an additional folder inside the destination folder.
Note: The Multi-language (Other languages) model supports all languages.
However, for better search quality, we recommend using a dedicated language model whenever one is available.
| Language | Download | Destination folder |
AI Classifier model
The AI Classifier model enables AI-powered classification, image similarity search, and text search.
Download the archive and extract all its contents into:%localappdata%\Kstudio\AI-Engines\config\ViT-L_14
Keep the text_encoder subfolder from the archive. Do not rename any files and do not create an additional nested ViT-L_14 folder.
After extraction, the folder structure must be:%localappdata%\Kstudio\AI-Engines\config\ViT-L_14\clip_visual_l14@226.onnx
%localappdata%\Kstudio\AI-Engines\config\ViT-L_14\text_encoder\clip_text_l14.onnx
%localappdata%\Kstudio\AI-Engines\config\ViT-L_14\text_encoder\bpe_simple_vocab_16e6.txt.gz
Original price was: $60.00.$42.00Current price is: $42.00.Add to Cart
