- July 11, 2018 at 13:56 #16188
Joe
ParticipantPosts: 3Threads: 4Joined: Dec 2013I found that the latest versions of this issue occur in Asset Files. When I open the first MAX file for Search & Collect, everything works fine, but when I open the second file, Asset Files will not find any files. Reopen the file unless you turn off max.
- July 11, 2018 at 13:59 #16193
ModeratorPosts: 264Threads: 1285Joined: Aug 2009Try refresh the scene manually.
Menu item “Refresh Assets” in the menu “Tools”
- July 11, 2018 at 14:05 #16194
Joe
ParticipantPosts: 3Threads: 4Joined: Dec 2013The problem has been solved by importing the settings, and the .ini file may be damaged again.
Thank you so much!
