  • #28390
    WOOWSTUDIO S.r.o.
      we found “comments” feature very handy when it comes to searching for a desired models in a model library that we are currently working on.
      However, we found that the comments are not saved for a models that were made (and saved) in early verions of 3dsmax (e.g. 2008 and so).  On the other hand, when we are adding comments to models saved in more recent versions, it works completely fine. Is there anything that can be done in this case, so we can add, store and use comment for those older models?
      Thank you for you answer in advance.
    Plugin version: 3.10.32
    3ds Max version: 3dsmax SP3
    Renderer: vray
  • #28393
      I’ll check for such possibility.
  • #28417
    WOOWSTUDIO S.r.o.
      Thank you!  We’ll be glad if there will be some solution for that issue.
  • #28428
      This works for max files older version is well on my side. Please generate the bug report and attach one from your max files.
