  • #16182
    Jared Hopkins
    Threads: 10
      I have a question from my team.  We are debating the best way to handle a certain library we are creating, create separate models for a series of signs, or one file that has all the signs in it.
      Anyway, the the sticking point seems to be that whenever you import a model from Project Manager, the object is grouped.  So if I have a one file with several models…it’s one giant group.  Is there away to change this?  As it seems to be default.  Just curious.
      Cheers,
      -Jared
    Plugin version: 2.91.07
    Renderer: Vray
  • #16185
      Hello!
      You can merge model without creation a group by double-click on the file or you can hold the SHIFT key when drag model into viewport.
      If you use the SHIFT key you receive a dialog with ability to chose an action. Simple choose a “Merge File” item such on first video in next article.
      Working with Models in Project Manager
  • #16224
    Jared Hopkins
    Threads: 10
      Hey Alexander,
      Yep you were right!  Turns out most of my team wasn’t on the latest version of Project Manager.  Go figure.
      Thank you,
      -Jared
