Viewing 6 posts
  • #23926
    Zhang Jian Hua
    Threads: 4
      我在使用中遇到了一个问题,当我启动项目管理插件后,我在3DMAX中不能用热键“CTRL + C”将已经创建的任何相机匹配到当前视图。这个问题有方法解决吗?谢谢
    Plugin version: 3.07.82
    3ds Max version: 3d max 2019
    Renderer: vray corona
  • #23932
      Please describe step by step what you do before hotkeys stop working.
      Try this hotkey before running PM. Are they work? And try after running PM.
      Note that viewport must be active for using this hotkey.
      Also, try to install the latest updates for 3ds Max. Usually, this solves most problems.
  • #23949
    Zhang Jian Hua
    Threads: 4
      在运行PM前,这个热键能将选择的相机匹配到视图工作正常。运行PM后,此热键只能为当前视图创建相机。
    • #23973
        Thanks for the useful description. This bug will be fixed in the next version.
  • #24010
      This issue is fixed in version 3.07.90
  • #24162
    Zhang Jian Hua
    Threads: 4
      非常感谢你的修复,我在新版中没有再遇见这个问题了
      <div id=”trans_main” style=”opacity: 0; display: none;”></div>
Viewing 6 posts
