Batch Archiving
Use Project Manager to archive multiple 3ds Max files and Material Libraries at once, collecting all linked assets, including all xRefs at all depth.
This is an extremely useful feature for backing up your projects and models, transferring data to another location, or rendering on a render-farm, such as RebusFarm.
Just run the “Batch Render&Relink*”, add a folder (folders) or some 3ds Max files or a material library, specify the folder where you want the data stored, and shortly you will have all the archives ready.
*Applicable to the 3ds Max utility “Batch Render&Relink” and Windows application “Batch Relink” The utility “Batch Render&Relink” which shipped with Project Manager and FilePathFinder PRO. Also, you can acquire “Batch Render&Relink” as a separate tool
- Add files/directories for archiving 3d files with assets
- Specify the path to store archives (supports full and relative paths)
- Turn on the Batch Asset Tracking option
- Turn on the Search&Relink option (optionally)
- Turn on the Fast Mode (recommended, optionally)
- Turn on the Archive files
- Turn on the Process xRefs (recommended, optionally)
- Run the process by pressing the START button
The archives will, of course, contain the source files for the scenes and materials. When opening a scene from the archive on another computer, all links will remain valid, because the links during archiving are made using relative paths.
Before archiving, you can use Search&Relink option to search for missing links, if necessary.
For the target folder, you can specify both full and relative paths. For the latter, use <FilePath> and <FileName> masks.
PS. Previously, this feature was only available with the Project Manager API
With Project Manager, you can write scripts expanding the features of the plugin in a way that you specifically need for your tasks.
This makes Project Manager incredibly flexible and you can always, if necessary, tailor it to your everyday needs or even to the needs of a particular project.
How does this handle xref scene files? does it copy them and relink them too? if not how do I batch merge xref scene files into the scene post open?
Batch Render&Relink allows processing xRef scenes with the parent scene. Just turn on the “Process xRefs” option
