Viewing 7 posts
  • #9710
    appius
      hi
      i’m using the very useful instance mat by name script, but sometimes the number of duper name is bigger than the slot number when i populate it, so I can’t check all materials before to instance them.
      unfortunately, it seems that the script instances all dupe mat, non only those visible in mat editor…
      is there something i could do?
      thx in advance.
  • #9711
    Threads: 1229
      I will add the support to Slate Material Editor.
      You will be place the any number of duplicate materials into the Slate Material Editor.
      I hope it solve this issue.
      Thanks for feedback.
  • #9712
    appius
      nice, thanks!
      any way to be warned when it’s done?
  • #9713
    Threads: 1229
      Completed!
      You can download the TrackScripts pack on this page.
  • #42015
    Threads: 2
      Hello,
      Thank you so much for the script.
      The script is working only VRayBlendMtl to VrayBlendMtl and VRayMtl to VRayMtl instance.
      Is it possible can we add two check box
      1. Instance by name and
      2. Instance by class.
      I want to explain why we need it.
      When i am importing model form other software then 3ds max apply standard material by default
      and name the material as it is given in other software.
      If scene already has same name VRayMtl and i import revised model from other software.
      It has StandardMtl and same name but script can not instance.
      Every time i need to convert StandardMtl to VRayMtl then run script.
      Script instance both material when both materials are VRayMtl.
      But when scene has VrayBlenMtl and i am importing revised model from other software.
      Is it possible both material instance by name only?
      Thanks
    • #42020
      Threads: 1229
        Thanks for your idea
  • #42238
    Threads: 2
      ok thanks!
      Any update about script . . . ?
Viewing 7 posts
