  • #32647
    Adrian Oostergetel
    Threads: 2
      Hello!  It would be great if you could have a light selected, for example a red shift dome light, and be able to browse hdri’s and apply them to the light from within project manager.  With an ipr render view open you could instantly see how your scene lights.
  • #32652
      Select VRay Dome light and drag HDR map onto the related slot.
      Note: Project Manager since version 3.15.12 uses spherical types for environment and dome lights
  • #32657
    Adrian Oostergetel
    Threads: 2
      Thank you, but annoyingly this doesn’t work for Redshift lights… or bokeh Images on cameras using the Redshift Camera Effect modifier.
      Bokeh ImageBokeh
  • #32667
      I checked again and as see the Redshift physical lights are supported – so you can drag bitmaps directly onto map button.
      For assigning an image to Redshift Camera Effects use the copy/paste option (copy desired image path from PM and after click the related button on the modifier and paste the path from clipboard)
