Viewing 7 posts
  • #9761
    Joe
    Threads: 4
      I can’t drag and drop a .max format file.
      Use shift-drop methop is ok.  But it is not convenient。
      *.3ds format is ok.
  • #9762
    Threads: 1285
      Please generate the bug report (menu “Project manager” ==>> Create support Request)
      Thanks for feedback.
  • #9763
    Jérôme Gonsolin
    Threads: 2
      Same bug for me !
      I’ve tried to generate the bug report but it fails to send the report (max script listener opens and say “can not merge”)…
      Please help ! PM can’t be used at all !
      Thanks!
  • #9764
    Threads: 1285
      All right – i receive the report.
      Please find me on skype: alexkstudio for faster solve the problem.
  • #9765
    Threads: 1285
      Solution – change the state of the “Material Merge Options” to any another and back.
      Or close the 3ds max and remove the ProjectManager.ini file.
      As a rule the path to scripts is located here:
      “C:\Users\USERNAME\AppData\Local\Autodesk\3dsMax\20XX\ENU\scripts\TrackScripts\ProjectManager\”
      Thank to Joe for help!
  • #9766
    Jérôme Gonsolin
    Threads: 2
      ok, working now !
      For me i had to completely erase “projectmanager” folder and reinstall it…
      Thank you for the support !
      Just another thing that as been probably already discuss: i can’t “directly” drag and drop rigged models (i get it without bones). It only work holding “shift” and choosing merge option… Am i wrong ? Is there another way to add rigged models in my scene?
  • #9767
    Threads: 1285
      Hi, Jérôme.
      Excellent.
      I move the question about rigged models to new post.
Viewing 7 posts
  • The topic ‘update V2 Can’t drag and drop files’ is closed to new replies.
