- February 20, 2017 at 17:33 #10725
Erik Clemens
ParticipantPosts: 4Threads: 3Joined: Jan 2013Thunbnails do not render correctly on objects that have VRayDirt material applied.
I suppose this is because the objects are scaled down to fit the view, and VRayDirt uses an absolute value for the radius.
Would it be possible to move the camera to fit the object, instead of scaling the object to fit the view?
Plugin version: 2.60.28
3ds Max version: 2017.1.1
Renderer: VRay 3.50.03 - February 20, 2017 at 17:38 #10727
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Same problem as in this topic
Will be fixed in next version.
Thanks for feedback.
- March 4, 2017 at 22:53 #10831
Michal Ziobro
ParticipantPosts: 21Threads: 40Joined: Mar 2015As I noticed same problem is with displacement
