- December 23, 2022 at 15:17 #37858
1144636510@qq.com
ParticipantPosts: 1Threads: 0Joined: Dec 2022When vray6 is installed, the plugin loads slowly, and it takes about 30 seconds to fully open. After uninstalling vray, the plugin loading speed is normal.
https://drive.google.com/file/d/1QccXejWymMd497Dw3Tvp3iORJSAcOAhF/view
Plugin version: 3.18.34
3ds Max version: max2022
Renderer: vray - December 23, 2022 at 15:19 #37868
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Check if don’t block Vray License server in the firewall
- January 16, 2023 at 18:46 #37996
Harold Rinck
ParticipantPosts: 17Threads: 24Joined: Jun 2012Hi,
I noticed in 3.18.83 slow open plugin too.
I have vray installed ( demo ) but the renderer is Octane render. 3dsmax 2022
It is not like this before.
Thanks
- January 17, 2023 at 14:16 #38000
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Check the settings for your firewall. It might be the same problem with Octane or your version of Vray.
Also, you can generate a support request.
