- May 17, 2025 at 20:53 #44764
Javier Marín
ParticipantPosts: 2Threads: 2Joined: May 2018When I drag PM to a second monitor, it disappears
Plugin version: 3.38.19
3ds Max version: 2023
Renderer: Vray - May 17, 2025 at 20:54 #44766
ModeratorPosts: 264Threads: 1285Joined: Aug 2009- Check Graphics Settings:
Ensure your monitors are correctly configured in your display settings. Verify that the second monitor is recognized and set as an extended display. - Disable Scaling:
If you’re using Windows, check the display scaling settings. Large scaling values might prevent some windows from being moved to another monitor. - Verify Window Modes:
Ensure that PM is not set to full-screen mode. Try switching to windowed mode before moving it to the second monitor. - Check for Software Conflicts:
Other programs, like window management tools or specific graphics-related utilities, might be interfering. Temporarily disable these tools to see if it resolves the issue. - Graphics Driver Update:
Outdated or incompatible graphics drivers could cause this behavior. Update your GPU drivers to the latest version from the manufacturer’s website. - Test on Another User Profile:
If possible, create a new user profile on your system and check if the issue persists. This can help identify if the problem is related to your current profile settings.
This issue might be related to settings or software conflicts on your system. Here are some steps to troubleshoot the problem:
PS: A few months ago, a user faced a similar issue, and reinstalling their graphics drivers helped resolve the problem. It might be worth trying this step as well!
- May 19, 2025 at 19:08 #44776
Javier Marín
ParticipantPosts: 2Threads: 2Joined: May 2018Thank you. Problem solved.
