  • #23254
    WOOWSTUDIO S.r.o.
      we purchased Project Manager 3 a few days ago and currently testing it. However, it seems that there is no option for writing tags for given model and searching for this model in model database based on these tags (like it is in 2.x versions). Is it planned that this function will be later implemented?
      We also noticed a strange lagging of a manager when model is selected. This problem is not happening in 2.97.15 version (we use 3dsMax 2017).
    Plugin version: v.3
    3ds Max version: 2017
    Renderer: FStorm
  • #23323
      Tag system changed and now you access tags through the panel at the bottom left, which called “Favorites”.
      Just drag items to the desired tag (Favorite ) for assigning.
      So now you don’t need for search item by tag – just open the desired Favorite. The capabilities of working with Favorites will be expanded in future versions.
      Please write more about this bug. Make the screenshot or short video for explaining.
      What version of Project Manager do you use?
