Viewing 13 posts
  • #27180
    3dwannab
    Threads: 15
      Here are the filename of the max files and the images I want to auto-assign.
      CGAxis 001 – Plants 002_Corona.max
      CGAxis 001 – Plants 001_Corona.max
      Is it possible to add an option to the new feature for regular expressions or is my naming scheme possible with the current features?
      So a filter could be used such as (which has (?i) for turning off case sensitivity so that the filenames case doesn’t matter):
      (?i)(_render.*|_corona.*|vray.*)(\.)(jpg|png|max|obj)$
      As you can see the jpg and the max files both have the same final name so that PM could then match the same image files to the max files as in this example.
    Plugin version: 3.09.15
    3ds Max version: 2020
  • #27186
    Threads: 1197
      Switch to Fuzzy search and use the next text in the “Ignore”
      <regex:\d{3}(_render|_corona|\s\d*|wire)>
  • #27187
    3dwannab
    Threads: 15
      I did try yours and one of mine which resulted in all the previews getting assigned to each max file
      My regexp:
      <regex:(_Render.+|_Corona.+)>
      See attached the result (along with a suggestion for showing the number of preview if they exist)
  • #27188
    3dwannab
    Threads: 15
  • #27189
    Threads: 1197
      Please run this command in the Command Promt and send a file “myfiles.txt” to support@3d-kstudio.com
      dir c:\path_to_models /s/b ->myfiles.txt
  • #27190
    3dwannab
    Threads: 15
      Done. What in regards the numbers of the previews. Is that something you’d consider?
  • #27195
    Threads: 1197
      Version 3.09.18 gains the ability to specify the level of similarity of filenames.
      In your case the ignore should be next: <regex:_corona|(_render\s\d*|wire)>
      And Difference should be set to “Similar“.
      Auto-assign preview to 3D Asset using Project Manager
      I’ll add this to the feature list.
  • #27202
    3dwannab
    Threads: 15
      Thanks, that’s working but it has brought up a new issue for me.
      It is assigning the _wire images to the first image in the preview. How could I get it so that the _wire images get assigned last? The order is reversed as to what File explorer is showing.
      This is the order as shown in the file explorer.
  • #27206
    Threads: 1197
      Ok. Maybe I should add the new block like “Order rules” to the settings.
  • #27207
    3dwannab
    Threads: 15
      Yes, a-z and z-a and whatever you decide. Cheers.
  • #27377
    3dwannab
    Threads: 15
      Just wondering if you have added the sorting in the latest release? 3.10.10
      Thanks for adding the numbers for the previews.
  • #27706
    Threads: 1197
      This feature in development.
      Thanks for your idea!
  • #30198
    Threads: 1197
      Project Manager version 3.13.00 gains the ability to sort and exclude files from the Gallery
      These settings apply automatically on auto assigning. Also, you can apply these rules for selected items or to all items in the database.
      You can download this version from the dashboard.
      Thanks for your ideas!
      PS. Type words in quotes.
      <_wire><_ambient><word3><etc>
      Sorting&Exclusions for Asset Previews
      [Resolved]
Viewing 13 posts
