- July 1, 2025 at 14:37 #45116
images
ParticipantPosts: 2Threads: 6Joined: Jan 2023Hi! I have a problem when I import the my settings of the project manager in others computers of the studio.
When I select help -> select folder with settings -> i check all the boxes include Exlude.ini.
The settings that I prepared for all the team seems to work except for 2 things:
1 – the hidden folder, that remain visibile in the other computer where i use my settings. (the folder that i hide in my project manager reamain visibile in the other computer)
2 – the colours that i prepared for the catalog disappear in the other computer of the team but it remain visibile in mine computer.
Thanks!
Plugin version: 3.35.75
3ds Max version: 3Ds Max 2025
Renderer: V-Ray / Corona - July 1, 2025 at 14:47 #45119
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Please send the directory with these settings to support@3d-kstudio.com
PS. version 3.35.75 is too old - July 2, 2025 at 18:23 #45121
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Hidden directory settings and node colors are stored in the file “TreeNodesData-SQLite.db”
- July 3, 2025 at 11:15 #45128
images
ParticipantPosts: 2Threads: 6Joined: Jan 2023Dear Oleksandr,
Thanks for the reply!
So when i export the settings , the colors “TreeNodesData-SQLite.db” will not include in the exportation automatically? So when i import my setting in the other computer i have to copy “TreeNodesData-SQLite.db” from my plugin’s folder and paste in the setting folder that i export?
I still have the same problem with folder exclusions. The only home-made solution I have found is to copy the files ‘Exclude’ and ‘ExcludeModels’ from my plugin folder and copy it for each computer where I want the same settings in the plugin folder. Because when I do import settings even though I tick the box ‘exlude.ini’ the exclusions do not remain in memory.
- July 3, 2025 at 11:20 #45129
So is enough to copy this file with the main database file
Maybe you don’t see this file in the list for importing, because you use the old version of the plugin. - July 3, 2025 at 11:54 #45130
images
ParticipantPosts: 2Threads: 6Joined: Jan 2023Hi Oleksandr,
We update the project manager to the version 3.39.80.
You are right about the “TreeNodesData-SQlite.db”, now during the exportation it keep in memory the colour.
But we still have the problem of the hidding folder. In my computer (i’m setting the preset of PM for all the studio), the folder are not visible (the ones I hid). In the other computer with my setting the folder are visibile.
- July 3, 2025 at 15:48 #45132
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Looks like the option “Show Hidden Folders” is on
- July 3, 2025 at 16:06 #45133
images
ParticipantPosts: 2Threads: 6Joined: Jan 2023The option hidden folders is disable if you mean the one that i attach you
- July 3, 2025 at 18:48 #45134
ModeratorPosts: 264Threads: 1283Joined: Aug 2009You’re right – I forgot to add another file type.
I fixed this in version 3.39.82.
“.data” file types are now also added to backups and included on import by default.
Thank you for bringing my attention to this issue. - July 4, 2025 at 10:20 #45135
images
Thank you very much for help us!
