Viewing 11 posts
  • #9691
    Peter Letten
    Threads: 0
      I’m getting this error message when I try to load certain material libraries and I think its only to mat files that I created from within Project Manager.  Has anyone else had this problem??
      I’ve done a lot of looking around other forums and this “Error Loading ParamBlock2” seems to be pretty mysterious and little understood.  From peoples threads its clear its been cropping up for years but due to different issues.
      Any help much appreciated as currently have lost access to my custom material library!
      Thanks
  • #9692
    Threads: 1285
      I not received other messages about the same bugs.
      Please generate a bug-report (menu “Project manager” ==>> Create support Request)
      and attach a problem material file.
      Thanks for feedback.
  • #9693
    Peter
    Guest
    Threads: 20
      I’m getting the same problem.
      Last time I had it when I added an XMap material (plugin from VizPark).
      Is there anyway I can access the mat file and remove any problem materials??  As I can no longer access the mat file from with Project Manager or 3ds max material editor.
      I’ll submit a support request now with a copy of the mat file.
      Thanks
  • #9694
    Threads: 1285
      Please attach the material library with problem.
      Did you mean that 3ds max can not access то material?
      In this case the Project Manager also can not work with this material.
  • #9695
    Threads: 1285
      One from your materials contains the XMap material.
      Check if you really remove it.
  • #9696
    Peter
    Guest
    Threads: 20
      But thats the problem – I cant access the .mat file because i get the error msg so I can’t remove the XMap.  Is there another way to view/edit a .mat file?
      Thanks.
  • #9697
    Threads: 1285
      Sorry – I wrote incorrectly.
      I mean – try to delete the plugin that used by xMap material – vp_xmap.dlt
  • #9698
    Peter
    Guest
    Threads: 20
      So you are saying uninstall XMap and then see if I can open the .mat file in max?
  • #9699
    Threads: 1285
      Yes – uninstall the Xmap.
  • #9700
    Peter
    Guest
    Threads: 20
      Thanks Alex – really appreciate the quick response.  I’ll try that and let you know how it goes – just cant uninstall it right now as busy on a deadline for a job thats using a lot of XMap.
      Presumeably you dont have XMap installed?  So you can open the .mat file ok?  If so, any chance you could delete the XMap material and send it back to me??
  • #9701
    Threads: 1285
      Ok – i sent  the materials to you.
Viewing 11 posts
