  • #39066
    DeathstarLXIX
    Threads: 0
      Hello,
      I’m new to the software and I’m learning to use the ‘Collect Files’ option. My question is: how is it possible to move the ‘bitmaps’ files into a specific folder instead of duplicating them ?
      I explain myself:
      I got 2 folders ‘A’ and ‘B’, without any subfolders, containing the .max and the jpg’s for the material altogether.
      When I use the ‘Collect Files’ with a specific location for each folder named “Maps” (folder A has a subfolder Maps’, same for B), the jpg are being duplicated to these Maps subfolder and are still present in the A and B folder.
      Is it possible to move them to the location folder instead of duplicating them ?
      Thanks a lot
  • #39069
      Unfortunately, currently this option doesn’t present. Moving in most cases will break links from other scenes/material libraries. So copy option is safer.
    • #41124
      Oleg R
      Threads: 4
        Hello Oleksandr,
        The “move” option is indeed sometimes essential.
        Let’s imagine a situation I had one week ago.
        The user received, for example, 100 new models and observed the following:
        – Some textures are in the same folder with maxscene.
        – Some models have a “tex” folder containing textures.
        – Some have a “map” folder
        – And others have a folder named “textures”.
        If I want to make it more organized and have the textures always in folders called “maps”, then currently with ProjectManager, I can automatically create “maps” folders and copy the textures there.
        However, I then need to manually go through again and delete all the old folders, which is not necessary if I had this “move” checkbox option.
        Best Regards
