  • #39769
    Rossen Mitov
    Threads: 11
      As the title says, I am getting an application Error at 3ds Max startup after installing Project Manager 3.23.36. I can’t do anything in 3ds Max except so I have to forcefully end the 3dsmax.exe process from the Task Manager. The only way to fix it was to uninstall Project Manger. Please see the screenshot below.
    Plugin version: 3.23.36
    3ds Max version: 3ds Max 2023.3.3
    Renderer: V-Ray 6 Update 1.2
  • #39774
    Threads: 1385
      Try the next:
      Install/reinstall the latest Updates and Service Packs for 3Ds Max
      Delete file “Kstudio-CacheStart.ms” from the directory
      %localappdata%\Autodesk\3dsMax\2023 – 64bit\ENU\scripts\startup
  • #39775
    Rossen Mitov
    Threads: 11
      I will try this out when I have some free time. Thanks! I managed to restore the previous version of the plug-in (3.18.68) and everything works fine for now. I will write back once I try your suggestion and report the results.
