- June 1, 2021 at 20:04 #32345
Lance Rewerts
ParticipantPosts: 2Threads: 0Joined: Nov 2017Get a runtime error when trying to start Project Manager in 3dsmax 2022. This is the case on several machines.
— Error occurred in anonymous codeblock; filename: C:\Users\rod\AppData\Local\Autodesk\3dsMax\2022 – 64bit\ENU\scripts\Kstudio\ProjectManager_3\Main.mse; position: 1056; line: 17
— Runtime error: .NET runtime exception: Method not found: ‘System.ValueType ManagedServices.MaxscriptSDK.ExecuteFloatMaxscriptQuery(System.String)’.
— MAXScript callstack:
— thread data: threadID:13804
— [stack level: 0]
— In anonymous codeblock; filename: C:\Users\rod\AppData\Local\Autodesk\3dsMax\2022 – 64bit\ENU\scripts\Kstudio\ProjectManager_3\CommonSettings.mse; position: 5955; line: 81
— Defined in encrypted script
— [stack level: 1]
— called from execute(); filename: C:\Users\rod\AppData\Local\Autodesk\3dsMax\2022 – 64bit\ENU\scripts\Kstudio\ProjectManager_3\Main.mse; position: 1057; line: 17
— member of: codeblock macroScript: Kstudio_Project_Manager_3
— [stack level: 2]
— called from codeblock macroScript: Kstudio_Project_Manager_3
— Locals:
— Externals:
— [stack level: 3]
— called from top-levelPlugin version: 3.10.23
3ds Max version: 2022.0.1
Renderer: Vray - June 1, 2021 at 20:05 #32347
ModeratorPosts: 264Threads: 1282Joined: Aug 2009Project Manager supports 3ds Max 2022 since version 3.14.15
Just upgrade to the latest version
