Viewing 5 posts
  • #9598
    Martin Kofoed
    Threads: 0
      Hi.
      My 3d studio max is crashing frequently.  Autodesk says that it may be caused by a plugin.
      Have you heard about these problems before.?
      I am using these plugins, and one of them is causing the problem:
      Project manager
      sigershader
      vray
      solidrocks
      The error is as following:
      FILE SAVE ERROR: Unknown class: SuperID =0x200, ClassID=(0x0,0x0)
      cheers Martin
  • #9599
    Threads: 1285
      Hi Martin
      Please type your version of  Vray and used Service packs and Hotfixes for 3ds max.
      You use 3ds Max or 3ds Max Design?
      Also please generate bug-report >>menu customize>>Preferences>>Make bug-report
  • #9600
    Threads: 1285
      I found the cause of this error.
      This occurs in 3ds max (not design) and Vray 2.0.
  • #9601
    Threads: 1285
      The problem is solved.
      Update will be available on the next week.
  • #9602
    Threads: 1285
Viewing 5 posts
  • The topic ‘3d studio max 2011 crashes’ is closed to new replies.
