- March 22, 2011 at 00:27 #2996
ModeratorPosts: 264Threads: 1283Joined: Aug 2009- Address bar
- Materials are stored with the modifier (UVW map, UVW xForm,
if appointed VrayDisplace and it included check Use object material, then VrayDisplace also stored) - Type display a list of Details (as in explorer)
- Sorting by name, date and file size
- Status bar slightly changed design and at bottom now writes the total size of files in a folder
- If you rename the file and it is present in the opening scene, it will change and the link to it .
- Now a batch render and search , collect and relink the files in batch mode is done via the utility “Batch Render&Relink”.
- You can change the paths in xRef-files without opening the file (available for max 2010 and above)
- Dark theme.
- Fixes a bug with render thumbnails for 3ds max 2010&2011.
- Fixes a bug for 3ds max 2011 when working with Slate Material Editor.
Related to "Project Manager v.1.32.21"
