Kstudio plugins are used by freelancers as well as in studios of different sizes – from several employees to hundreds.
This feature simplifies the deployment of numerous installations into a large network.
I recommend paying attention to utilities such as PsExec and PowerShell – with their help you can install the 3dsMax plug-ins and apply the license keys in a batch mode.
Using:
  1. Download and extract the archive SilentModeInstall.zip
  2. Copy the ZIP archive with the full version of the plugin into one folder with “AutoInstallStart.bat”
  3. Open “AutoInstallStart.bat” and uncomment/add a valid path to 3dsMax.exe
  4. Write activation keys to the file “Activation/ActivationKeys.txt”
  5. Run “AutoInstallStart.bat” using PsExec/PowerShell or manually on each computer
Note: Internet connection is required to use activation keys
Download example: SilentModeInstall.zip
See Also:
