Add Modifiers
Interface
Amount
Defines the extrusion depth.
From Center
Segments
Rotate X
Rotate Y
Cap Start
Cap End
Generate Mapping Coords
Real-World Map Size
Generate Material IDs
Use Shape IDs
Smooth
Sweep Profile Crowns-A 3
Project Manager
