Viewing 13 posts
  • #9870
    edward_turner
    Threads: 8
      I love your Track Scripts! They are just amazing.
      I used the camera lister a lot but unfortunatly the download you
      offer right not does not include the updated physical camera lister.
      It is still named vraycameralsiter and produces an error in max 2016 and vray 3.
      Did I do something wrong?
      Best regards,
      edward
  • #9871
    Threads: 1195
      Fixed.
      Please download the latest version.
      Thanks for feedback.
  • #9872
    edward_turner
    Threads: 8
      jihaaa!!
      works! thank you very much. You´re work is just amazing and important for the industry!
  • #9873
    lilacepeezy
      When I attempt to use the physical cam lister in Max 2015, I get an error message of Unable to convert: OK to type: point 2. How can I resolve this??
  • #9874
    Threads: 1195
      Please download the latest version of TrackScripts.
  • #9875
    Viki Malik
    Threads: 2
       hi,
        I use 3ds max 2015 and vray 3.4,When I attempt to use the physical cam lister in Max 2015, I get an error message of Unable to convert: OK to type: point 2.
      i have downloaded the latest version from your site but it still gives me this error by the way thanks for your script and time
      viki
  • #9876
    Threads: 1195
  • #9877
    Viki Malik
    Threads: 2
      Hi Kramer,
      Thanks for the Reply,Now it worked Thanks again for providing this script and your time
      Hope to see you doing great work in future bye.
  • #14419
    alexfmos
    Threads: 3
      Hello. Can you help me change the script. If i select cam pressing the first button, before camera name, cam selecting and change active viewport to that camera. I don’t want this action, i want only select cam, without change active viewport. Please, can i change somthing in files or somthing? And sorry for my bad english.
    • #14420
      Threads: 1195
        Remove next from script “viewport.setCamera $”
  • #14421
    alexfmos
    Threads: 3
      Thank you, it’s help,  but i have another question. I found 2 files in %localappdata%\Autodesk\3dsMax\2014 – 64bit\ENU\scripts\TrackScripts\
      VrayCamLister.ms and PhysicalCamLister.ms.
      And you advise delete string work only if i change VrayCamLister.ms Why PhysicalCamLister.ms not use? I must update script another way? I just drag’n’drop TrackScripts.mzp in to viewports.
    • #14422
      Threads: 1195
        Delete from both scripts.
  • #14423
    alexfmos
    Threads: 3
      I did it. I just think – it’s means i am use old version script. Not new.
      Well i think it does not matter. Thank you.
Viewing 13 posts
  • The topic ‘Physical Camera Lister’ is closed to new replies.
