Viewing 5 posts
  • #42151
    Gou Fushimi
    Threads: 2
      I have installed on max2024.
      I get an error message when I run the AlignPivot script because the [max2024] folder does not exist in the folder in the path below.Can you please address this issue as I like the script very much when I use it in max2022.
      C:\Users\xxx\AppData\Local\Autodesk\3dsMax\2024 – 64bit\ENU\scripts\Kstudio\AlignPivot\3Ds Max libs
    3ds Max version: 2024
    Renderer: Vray
  • #42157
      Scripts pack supported up to 3ds max 2025.
      Try to reinstall or run 3ds max in administrative mode and install the scripts pack
  • #42159
    Gou Fushimi
    Threads: 2
      Thanks for the reply. I reinstalled the software with administrator privileges, but when I run it, I get the following error.
      What is the cause?
      — [stack level: 0]
      — In node loop; filename: C:\Users\xxx\AppData\Local\Autodesk\3dsMax\2024 – 64bit\ENU\scripts\Kstudio\AlignPivot\ObjectPivot.ms; position: 9157; line: 338
      — member of: anonymous codeblock
      — Parameters:
      — node: $Box:Box001 @ [-7.487986,2.975138,0.000000]
      — Locals:
      — bb: undefined
      — objPivot: undefined
      — paintNode: $Editable_Poly:Box002 @ [-7.487986,2.975138,12.893110]
      — newPivotPoint: [-7.48799,2.97514,0]
      — detachNodes: undefined
      — origNode: undefined
      — boundLocal: undefined
      — pvData: undefined
      — xFormOrigNode: $Box:Box001 @ [-7.487986,2.975138,0.000000]
      — Externals:
      — useSmartMode: Free:useSmartMode : true
      — pointNumber: Free:pointNumber : 5
      — PivotData: StructDef:PivotData
      — useGlobal: Free:useGlobal : true
      — allPivotData: Free:allPivotData : #()
      — owner: <CodeBlock:anonymous>
      — surfaceNumber: Free:surfaceNumber : 5
  • #42161
      Looks like you tried to start scripts without restarting 3ds max or have incorrect settings for user privileges to 3ds max folders.
      Fix this and reinstall the scripts pack.
      Or add to the file “Plugin.UserSettings.ini” path to the GetObjectPivot.dlx (<path to enu directory>\ENU\scripts\Kstudio\AlignPivot\3Ds Max libs\3ds Max 2024\GetObjectPivot.dlx)
  • #42162
    Gou Fushimi
    Threads: 2
      It appears that the script could not be started because a corrupt file from a previous failed installation could not be updated during the reinstallation.
      We were able to get it to work properly by manually copying the files from the mzp file.
      Thanks!
Viewing 5 posts
