- April 27, 2014 at 22:46 #9728
- June 3, 2014 at 17:47 #9729
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Play with pivot alignment for fix it.
- June 4, 2014 at 12:14 #9730
Frank
GuestPosts: 13Threads: 20Joined:thx for your tip. I tried it, but the problem is that the sweep modifier does not handle self intersections when the curve becomes too tight for intersection-less sweeping. This problem arises on all sweep modifiers, also in Softimage. Seems it needs another level of logic, which has not yet been established in those modifiers.
Regards,
Frank
- June 4, 2014 at 19:04 #9731
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Maybe you need contact with developer of 3ds Max and Softimage.
- January 30, 2022 at 07:22 #34662
Mad Mady
ParticipantPosts: 0Threads: 2Joined: Jan 2022is this problem solved ? i am trying free version it is there so please tell me so i can buy pro if it is solved or going to be solved in future update
- January 30, 2022 at 10:36 #34665
Sweep Profile script based on the standard 3ds Max modifier Sweep
- January 30, 2022 at 19:56 #34667
Mad Mady
ParticipantPosts: 0Threads: 2Joined: Jan 2022is that problem solved or any chances for solving that problem of overlaping
- January 30, 2022 at 21:59 #34668
ModeratorPosts: 264Threads: 1283Joined: Aug 2009This is a specific of the 3ds Max modifier Sweep, developed by Autodesk.
