- October 7, 2016 at 17:48 #9957
tschuelke
ParticipantPosts: 5Threads: 2Joined: Oct 2016::Hallo,
well we own this Plugin now for a few days and think it will fit great in our workflow.
now. i have integrated some xfrog libaries with trees that use standart material.
i know in the Plugin theres a section to let external scripts to be done. And what i would lilke to do is to change all the standartmaterials of my lybery in the xfrog trees to vray materials, converting every bitmap to its correspondent vray place..
and further more i would like to switch the way to calculate opacity maps to “clip” …
are there good scripts out there, any idea, and the exact workflow inside of Project Manager ?
thanks for help
- October 7, 2016 at 18:11 #9958
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Project Manager have some API methods – so you can write custom extensions.
https://3d-kstudio.com/tag/api/
You can find examples in the directory “ProjectManager\presets”.
Also i can write it’s for you – please send description about to mail support@3d-kstudio.com.
Of course this paid separately.
- October 7, 2016 at 19:01 #9959
tschuelke
ParticipantPosts: 5Threads: 2Joined: Oct 2016Well is there no way just to point to any existing easy script for vray-material-conversion ?
and the rest is done automaticaly ?
well i guess no..
- October 8, 2016 at 19:34 #9960
ModeratorPosts: 264Threads: 1283Joined: Aug 2009In any way you must specify files what you want to process.
