Viewing 6 posts
  • #9685
    Threads: 5
      Is there a way to xRef proxies in Project Manager?
      In PM there is just “Merge as Proxy” or “Merge as xRef”. But I would like to use both options!
      Thanks,
      Ricardo
  • #9686
    Threads: 1280
      No – the Project Manager not has ability for merge xRef-proxies.
      The option “Merge as Proxy” not has any sense to xRef.
      You can use the option “Merge as Proxy” for merging a 3d model as Vray or Mental Ray Proxy.
  • #9687
    Threads: 5
      I know what xRef and proxies are for. I think I wasn`t clear, let me try to explain better.
      I want to xRef my merged models because I can update them inside my host scene and keeping my library updated automatically. Ok, 3ds Max and PM can do it easily.
      But.. if want/need the use of proxies? They are a must often. So, is there a way to merge proxies with the use of xRef? I wish PM could do it.
  • #9688
    Threads: 1280
      The xRefs can contains any type of objects (of course also Vray or MentalRay Proxy).
  • #9689
    Threads: 5
      Yes, you are right. Thank you.
  • #9690
    Threads: 5
      Hello Alex,
      One more thing please.
      Every merged models as xRef with Project Manager are automatically set with “Merge Transforms” and “Merge Materials” on, even when those setting are off by default in xRef Object dialog box. Would be nice if PM could maintain the settings settled in the dialog.
      With these settings always on, the usage of xRef get so limited!
      Thanks,
Viewing 6 posts
