- June 16, 2013 at 03:41 #9685
Ricardo Borges de Freitas
ParticipantPosts: 1Threads: 5Joined: Jun 2013Is there a way to xRef proxies in Project Manager?
In PM there is just “Merge as Proxy” or “Merge as xRef”. But I would like to use both options!
Thanks,
Ricardo
- June 16, 2013 at 17:10 #9686
ModeratorPosts: 264Threads: 1285Joined: Aug 2009No – the Project Manager not has ability for merge xRef-proxies.
The option “Merge as Proxy” not has any sense to xRef.
You can use the option “Merge as Proxy” for merging a 3d model as Vray or Mental Ray Proxy. - June 16, 2013 at 21:46 #9687
ParticipantPosts: 1Threads: 5Joined: Jun 2013I know what xRef and proxies are for. I think I wasn`t clear, let me try to explain better.
I want to xRef my merged models because I can update them inside my host scene and keeping my library updated automatically. Ok, 3ds Max and PM can do it easily.
But.. if want/need the use of proxies? They are a must often. So, is there a way to merge proxies with the use of xRef? I wish PM could do it.
- June 18, 2013 at 22:52 #9688
ModeratorPosts: 264Threads: 1285Joined: Aug 2009The xRefs can contains any type of objects (of course also Vray or MentalRay Proxy).
- June 19, 2013 at 05:47 #9689
ParticipantPosts: 1Threads: 5Joined: Jun 2013Yes, you are right. Thank you.
- June 24, 2013 at 06:32 #9690
ParticipantPosts: 1Threads: 5Joined: Jun 2013Hello Alex,
One more thing please.
Every merged models as xRef with Project Manager are automatically set with “Merge Transforms” and “Merge Materials” on, even when those setting are off by default in xRef Object dialog box. Would be nice if PM could maintain the settings settled in the dialog.
With these settings always on, the usage of xRef get so limited!
Thanks,
