Viewing 11 posts
  • #10946
    Nicolas Balagny
    Threads: 9
      We  have very long loading times when we open the material tab. Max is freezing for ~10 seconds. After the freezing time i open a library with very long loading times. Same when i surch for materials with the namefunktion. We have this on several machines. We added the materials with the “folder-funktion”. Do you know this issue? What do i have to do?
    Plugin version: 2.60.28
    3ds Max version: 3dsmax 2016 SP 4
    Renderer: Vray
  • #10947
      Materials that contains a missing network paths can render in interactivity a preview very slow.
      So for solving you can render images using the Batch Render&Relink tool, disable interactive rendering for materials or fix network paths using the Batch Render&Relink tool.
      Also you can try do next:
      1. Install the latest updates for 3Ds Max
      2. Uninstall if use the plugin vfb+ ( if exists )
      3. Completely uninstall the Project Manager ( including setting ). Before this you can backup your settings
      4. Install it again and test.
      Thanks for feedback. Please write if it will help your.
  • #10948
    Nicolas Balagny
    Threads: 9
      ok, i think the missing network path caused the problem. Much better now. Thank you for your fast support.
  • #10950
    Nicolas Balagny
    Threads: 9
      hmmm, in huge scenes there is still the problem. i´ll check the other points you recommmented and give you feedback again
  • #10997
      Ok.
      Please write what from proposed solutions will help your.
  • #11029
    Nicolas Balagny
    Threads: 9
      here we go:
      i did some tests. now i think the problem is when there are many materials in the scene. I tested some scenes with much materials in scene. One Scene was 700 MB the other was only 5 MB. In both the PM was laggy and freezy (in Material Tab). All maps are ok and the path was valid. Then i deleted all scene materials and – voila: the  material Tab in the PM works fast and without any issues.
      Do you know about this Problem?
  • #11030
      You very help me for solving this problem if send this large scene to me – support@3d-kstudio.com.
      Thanks!
  • #11031
    Nicolas Balagny
    Threads: 9
      u got mail
  • #11039
      Big thanks!
      You very help me.
      Soon i will post the update for fix a problem with slow loading materials on complex scenes.
  • #11040
    Nicolas Balagny
    Threads: 9
      nice! this sounds hopefully :)
  • #11041
      Fixed in version 2.60.29
      • Fixes an issue with very slow loading material libraries on complex scenes when use a Nitrous Direct3D Display Driver.
Viewing 11 posts
  • The topic ‘Very long loading times when opening the "Material Tab"’ is closed to new replies.
