Viewing 10 posts
  • #19695
    Hypershade
    Threads: 8
      Thumbnails are rendered fine but not saved with Corona 4.
      This is the error message in the listener.
      — Address: 0x511f04fd; nCode: 0x00000000C0000005
      — Desc: EXCEPTION_ACCESS_VIOLATION The thread tried to read from or write to a virtual address for which it does not have the appropriate access.
      — Read of Address: 0x0000000000000000
      Please help to solve or fix this problem.
      Thanks.
      Ps.: how can I switch to the corona VFB for thumbnail rendering?
    Plugin version: 2.96.02
    3ds Max version: 2019
    Renderer: Corona 4
  • #19698
      This is a bug in Corona 4
      Corona 4 generates the exception on rendering start with simple maxscript command
      bm = render vfb:false
      You can report about this bug to developers.
  • #19700
    Hypershade
    Threads: 8
      Where and when should I run this? “bm = render vfb:false”
      If I run it before thumbnail rendering in the listener, it will give a lot of errors.
      I will report it to the Corona devs.
  • #19727
      Thank.
      I’m also created the ticket to Corona developers.
      Hope it will be solved soon.
      As a temporary solution you can use this script Fix bug rendering in Corona 4.ms
      Place it to “Post-open Script” field in Batch Render&Relink
  • #19730
    Hypershade
    Threads: 8
      Hi Alex,
      Thank you very much.
  • #19778
    Demetrio Ruivo
    Threads: 6
      Hi Alexander,
      I’ve added the script to the “Post-open Script” location on batch render&relink, but still no go.
      Now it won’t render the thumbs at all, nor will it write new thumbnails.
      Hope to see the new update come soon, thanks.
    • #19780
        • Add script to the “Post-open Script” field
        • Turn on the rendering.
        • Add files/folders for rendering
        Or maybe you need uncheck the “skip existing thumbs” option?
        Please post the screen of your settings. Main window and “Render Thumbnails Preferences” dialog.
        PS. Corona developers are writing about the update next week.
  • #19902
    Demetrio Ruivo
    Threads: 6
      Hi Alexander,
      have a look at the way the thumbnail rendering process is setup – Despite the following of your suggestions, I still don’t manage to get updated thumbnails. Is there an outlook on the time it will take to set this up?
      let me know, Kind regards,
      Demetrio
      Setup
    • #19906
        I think that understood the problem.
        Did you try render from Project Manager? Didn’t use Batch Render&Relink?
        This solution works only for Batch Render&Relink.
  • #19969
Viewing 10 posts
