Viewing 10 posts
  • #43922
    rosher denis
      Thumbnails in the material gallery are displayed in very low quality.
      much worse than in material editor of 3d max
      Is it possible to configure this somehow?
      max 2024 Corona 12
      windows 11
      GeForce RTX 3060
    Plugin version: 3
    3ds Max version: 2024
    Renderer: corona 12
  • #43927
    Threads: 1282
      This is limitations of interactive rendering preview.
      Just render preview to get better quality.
      You can render preview one by one or using Batch Render tool, shipped with Project Manager
  • #43943
    rosher denis
      THANKS A LOT
  • #44273
    Krzysztof Levin
    Threads: 4
      Hi!
      I have a ambient occlusion shader. It is a standard Arnold material with AO map. It is fine to add it to materials but when I go to thumbnails and render it, it renders a flat white color map instead of a sphere or a material globe. Also, is it possible to assign your own custom thumbnails from disk?
  • #44276
    Threads: 1282
    • #44294
      15810142059a
      Threads: 5
        Hello, based on my testing, the plugin doesn’t seem very friendly with Arnold. When using thumbnails, specifying the use of the Arnold renderer always fails. Is this the case?
  • #44280
    Krzysztof Levin
    Threads: 4
      thank you. I did replace substance thumbnails. It all went ok, until the previews dissapeared for some reason and they refused to be replaced again. I drag the thumbnail into the PM but nothing happens. I worked really hard on this so Im sort of bummed now. I do not know what to do.
    • #44304
      Krzysztof Levin
      Threads: 4
        Did you link it in rendering settings?
  • #44281
    Krzysztof Levin
    Threads: 4
      3dsmax freezes sometimes to the point that I have to restart it again when dragging thumbnails. But I did figure out why they won´t show up. There is a number on each, and that is how many images there are for the shader. I have to delete them, and then drag into position. So I guess, it´s not that bad.
    • #44282
      Threads: 1282
        It shouldn’t freeze. It looks like a bug. Please generate a bug-report.
Viewing 10 posts
