Viewing 5 posts
  • #32296
    Threads: 14
      Hi. I bought Project Mananger to solve my messy libray. I have a few questions / suggestions. Please, let me know if I´m posting in wrong section.
      I´m organizing: Each 3d model is inside a folder with preview file, .max file and textures. But thumbs has different names from max file, very different. Not lookalike with preview, _vray or _corona on it. Thumb has one crazy code and max file is named: Deco_set_7.max. Making very difficult to auto-assign
      So, a few questions:
      1. Is there a way to filter to show only files without thumbnail, so I can easily locate and fix manually?
      2. Is there a advanced video to find how to use the strings in auto-assign? (I tried, but everything appears on thumb, except the correct one)
      Thanks.
  • #32315
    Threads: 1239
      Auto-assigning will not work if no system in file names.
      So you can render preview again or assign preview by dragging preview to related file
  • #32316
    Threads: 14
      Ok, I´m finding and renaming thumbs files. It´s a very manual process, but it´s pontual.
      But, in project mananger, is there a way to show only files that don´t have thumbs associated?
      I just need to see what I need to work on and avoid keep scroll for hundreds of files to find this ones.
  • #32317
    Threads: 1239
      You can’t filter such files in the Project Manager but you can print such files to the maxscript listener using API
      ProjectManagerStruct = PMStructureInfo()
      selectedItems = ProjectManagerStruct.GetSelectedItemsInfo IncludeThumbnails:true
      for item in selectedItems where item.Thumbnail == undefined or not doesFileExist item.Thumbnail do
      format “%\n” item.Item
      [Resolved]
  • #32318
    Threads: 14
      Thanks, this will help a lot.
Viewing 5 posts
