Viewing 5 posts
  • #38820
    Sandra Massa
    Threads: 4
      Hello,
      One of My custom Arnold Material Templates has a scale for all image maps set to .23 and when I generate a new material using custom uv template the materials generated scale is at 1.0.  Please advise if there is a way to do this for Arnold image maps as I have a whole manufacture’s library where the material in real world scale is .23.
      Please note that I also tried setting the top where it says custom to .23 and that did not do anything.
      Thanks in advance,
      Sandra
    Plugin version: 3.20.16
    Renderer: Arnold
  • #38824
      Hello
      Please attach here or send to email your template material
      You can find it by this path %localappdata%\Kstudio\data\
    • #38826
      Sandra Massa
      Threads: 4
        Hi Alex,
        Ok.  I will email as attaching the Material.xml file did not work here.
        Thanks,
        Sandra
  • #38831
      Image size uses settings from these options
  • #38839
    Sandra Massa
    Threads: 4
      Thank you for pointing this out.  I know in the past I did set most of my fabric materials to 54 inches wide and it’s been a while, so I put in the size in the material uv maps.  Now looking to find this I see that I had the settings minimized.
      Thanks again,
      SandraSize settings for material were minimized
Viewing 5 posts
