Viewing 7 posts
  • #45265
    Threads: 3
      The new search button is worse now, it take longer to show results, it cant find files that are on the folder
      When the text is erased it shows no assets on the folder.
    Plugin version: 3.40.00
    3ds Max version: 2025.3
    Renderer: corona 12.1
  • #45267
      It seems you’ve been using the search box to try and filter files in a folder.
      We’ve now made search and filter two separate text fields: the search box sits at the top, and the filter box is directly below it.
      When you clear the filter text, all files in the folder will reappear immediately.
      Disabling Interactive Search
      If you’d like to turn off live (interactive) search, just open the menu beneath the search field and toggle it off.
      Empty View After Clearing Search
      You’re right that, once you delete your search term, the folder view stays blank—that’s how it worked before. Thanks to your feedback, we’ll update it so that clearing the search box automatically restores the folder contents in the next release.
      Hope that helps!
  • #45303
    Threads: 3
  • #45306
  • #45308
    Threads: 3
      Thanks Oleksandr .40.26 fixed the issue :)
  • #45319
    Threads: 3
      Hi, i think the search bug is still present in the materials category
      Searching for a know material shows no results.
    • #45320
        The search for materials is limited to materials presented in categories
Viewing 7 posts
