Viewing 5 posts
  • #9732
    Travis Schmiesing
    Threads: 0
      Hi Alex,
      I am following up with a question that I posted on Scripspot… I am trying to save selected geometry and bitmaps associated with that selected geometry to a directory.  When I use save selected with Project Manager it only copies the bitmaps but does not save the geometry as well.  Is this way the tool is intended to work or am I missing a step?
      I am using MaxDesign2014 and Project Manger Demo.
      Thanks,
      Travis
  • #9733
    Threads: 1285
      Please attach the scene with object what you try.
      Thanks for feedback.
  • #9734
    Bragi
    Guest
    Threads: 20
      Has this problem been resolved?  I am having the same issue.  I tried the following
      1. Saving out 2 VrayDome Lights.
      Result – Saved a 3dsmax viewport thumbnail, saved the dome light texture (.hdr), but didn’t save a max file with the dome lights.
      2.  Saving out a building model (many pieces of geometry with different texture maps)
      Result – Saved a 3dsmax viewport thumbnail, saved out one bitmap, did not save a 3dsmax model
      3.  Saving out a building model which is grouped
      I tried all three of these both locally on my workstation on and on my company’s network, same results.
      So the question is, how do you save out a complete selection of several pieces of geometry and also get assets?  (bitmaps, etc.)
      Thanks!
  • #9735
    Threads: 1285
      Previously i did not find the issue and not receive the description from customer.
      I hope your description help me find and solve this bug.
      Thanks!
  • #9736
    Threads: 1285
      I tried to repeat but everything works.
      The code also not contains faults.
      Please try to remove your another scripts.
      Also you can install the TeamViewer and find me on skype as alexkstudio.
Viewing 5 posts
  • The topic ‘Save Selected Max Geometry and Textures’ is closed to new replies.
