Viewing 8 posts
  • #15843
    Joe
    Threads: 4
      Tested when using over  to save my model to the library will not automatically generate the corresponding name of the folder save the map and specify the correct path.
      The latest version only saves the model, and the map path still points to the original path, which is not conducive to organizing the library.
    Plugin version: over v.2.60.29
    3ds Max version: 2016
  • #15844
      Please update to latest version of Project Manager.
    • #15845
      Joe
      Threads: 4
        I have tried all the latest versions, only the version before v.2.60.29 will be correct
  • #15846
      Please generate the bug report
      and attach one from your file which didn’t save with maps
    • #15847
      Joe
      Threads: 4
        already generate the bug report with  the TV cabinet model
  • #15848
      Thanks Joe.
      But please send a files (zip and jpg) again through email ( support@3d-kstudio.com ).
      They didn’t attached.
  • #15859
      Solution: remove Project Manager’s ini file.
      [Resolved]
    • #15860
      Joe
      Threads: 4
        It’s working perfectly fine now. Thank you for your help and this excellent plugin.
Viewing 8 posts
